Local subtitles don't appear
Plex is not identifying local subtitles that are in the same folder as the movies or series. The subtitles have the same name as the video file and even then, they are not identified. The format is .srt.
can help?
Please post the first ~20 lines from the Plex XML info of an affected video.
Did you enable the display of file name extensions in the Windows file explorer? Otherwise you may believe that the subtitles have the same file name, while they actually do not.
External subtitles may sometimes only be recognised after Refresh Metadata of the item.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="2" librarySectionTitle="Séries" librarySectionUUID="83b84ac1-8a85-4249-bfb0-d1cc89350b00" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1685991844">
<Video ratingKey="14596" key="/library/metadata/14596" parentRatingKey="14579" grandparentRatingKey="14456" guid="plex://episode/5d9c1276ec357c001f9d06d3" parentGuid="plex://season/602e67d8b2c087002d0c727f" grandparentGuid="plex://show/5d9c086c46115600200aa30e" type="episode" title="Saindo do Armário" titleSort="Saindo do Armario" grandparentKey="/library/metadata/14456" parentKey="/library/metadata/14579" librarySectionTitle="Séries" librarySectionID="2" librarySectionKey="/library/sections/2" grandparentTitle="Seinfeld" parentTitle="Temporada 4" originalTitle="The Outing" contentRating="TV-PG" summary="Uma repórter pensa que George e Jerry são um casal e eles passam a ter diferentes sentimentos sobre a situação." index="17" parentIndex="4" audienceRating="9.2" viewOffset="355739" skipCount="4" lastViewedAt="1686309570" year="1993" thumb="/library/metadata/14596/thumb/1683928899" art="/library/metadata/14456/art/1683928717" parentThumb="/library/metadata/14579/thumb/1683928898" grandparentThumb="/library/metadata/14456/thumb/1683928717" grandparentArt="/library/metadata/14456/art/1683928717" grandparentTheme="/library/metadata/14456/theme/1683928717" duration="1338337" originallyAvailableAt="1993-02-11" addedAt="1683928816" updatedAt="1683928899" audienceRatingImage="themoviedb://image.rating" chapterSource="media">
<Media id="33495" duration="1338337" bitrate="14995" width="1920" height="1080" aspectRatio="1.78" audioChannels="2" audioCodec="eac3" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="24p" videoProfile="high">
<Part accessible="1" exists="1" id="41948" key="/library/parts/41948/1650309286/file.mkv" duration="1338337" file="R:\Seinfeld\Seinfeld.S04.1080p.AMZN.WEBRip.DD2.0.x264-NTb[rartv]\Seinfeld.S04E17.The.Outing.1080p.AMZN.WEBRip.DD2.0.x264-NTb.mkv" size="2508589666" container="mkv" videoProfile="high">
<Stream id="123742" streamType="1" default="1" codec="h264" index="0" bitrate="14995" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" codedHeight="1088" codedWidth="1920" colorPrimaries="bt709" colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="23.976" hasScalingMatrix="0" height="1080" level="40" profile="high" refFrames="4" scanType="progressive" width="1920" displayTitle="1080p (H.264)" extendedDisplayTitle="1080p (H.264)"> </Stream>
<Stream id="123743" streamType="2" selected="1" default="1" codec="eac3" index="1" channels="2" bitrate="224" language="Inglês" languageTag="en" languageCode="eng" audioChannelLayout="stereo" samplingRate="48000" displayTitle="Inglês (EAC3 Stereo)" extendedDisplayTitle="Inglês (EAC3 Stereo)"> </Stream>
<Stream id="123744" streamType="3" codec="srt" index="2" bitrate="0" displayTitle="Desconhecido (SRT)" extendedDisplayTitle="Desconhecido (SRT)"> </Stream>
<Stream id="146722" key="/library/streams/146722" streamType="3" selected="1" codec="srt" language="Português" languageTag="pt-BR" languageCode="por" format="srt" providerTitle="OpenSubtitles" score="0" sourceKey="/library/streams/1953464010?provider=OpenSubtitles&url=https%3A%2F%2Fdl.opensubtitles.org%2Fen%2Fdownload%2Fsrc-api%2Fvrf-19a30c4a%2Ffilead%2F1953464010.gz&enc=CP1252" title="057 - The Outing - [DVD]-por" transient="1" userID="1" displayTitle="Português (SRT OpenSubtitles)" extendedDisplayTitle="057 - The Outing - [DVD]-por (Português SRT OpenSubtitles)"> </Stream>
</Part>
</Media>
<Guid id="imdb://tt0697745"/>
<Guid id="tmdb://63160"/>
<Guid id="tvdb://304116"/>
<Rating image="themoviedb://image.rating" value="9.2" type="audience"/>
<Director id="22558" filter="director=22558" tag="Tom Cherones" tagKey="5d776ba447dd6e001f6e180b" thumb="https://metadata-static.plex.tv/c/people/c8fa0e92a6d7841124a5f7d34fe4e5b5.jpg"/>
<Writer id="22639" filter="writer=22639" tag="Larry Charles" tagKey="5d776826961905001eb910b9" thumb="https://metadata-static.plex.tv/people/5d776826961905001eb910b9.jpg"/>
<Role id="8097" filter="actor=8097" tag="Paula Marshall" tagKey="5d776835eb5d26001f1e0b44" role="Sharon" thumb="https://metadata-static.plex.tv/people/5d776835eb5d26001f1e0b44.jpg"/>
<Role id="6613" filter="actor=6613" tag="Anthony Mangano" tagKey="5d7768266f4521001ea98ca7" role="Marine" thumb="https://metadata-static.plex.tv/2/people/23fe1b1f55934d79f44a1d097f5d70d4.jpg"/>
<Role id="11258" filter="actor=11258" tag="Ben Reed" tagKey="5d7768b96f6af7001ee5bdb7" role="Marine" thumb="https://metadata-static.plex.tv/people/5d7768b96f6af7001ee5bdb7.jpg"/>
<Role id="22407" filter="actor=22407" tag="Lawrence Mandley" tagKey="5d776854103a2d001f56de3d" role="Manager" thumb="https://metadata-static.plex.tv/6/people/6b811e199b02b00e65a00e163da02ec3.jpg"/>
<Role id="23084" filter="actor=23084" tag="Charley Garrett" tagKey="6171842ec29ca4fb35fa58b8" role="Man #1"/>
<Role id="22394" filter="actor=22394" tag="Deck McKenzie" tagKey="5f3feb98fea1a1003f9a1845" role="Scott" thumb="https://image.tmdb.org/t/p/original/xl4joCvlAm7RowJUGfLySeqkY2z.jpg"/>
<Role id="23085" filter="actor=23085" tag="David Gibbs" tagKey="6171842ec29ca4fb35fa58b9" role="Man #2"/>
<Role id="5853" filter="actor=5853" tag="Tory Christopher" tagKey="6323e600be9bde8ef2776e21" role="Restaurant Patron"/>
<Role id="22460" filter="actor=22460" tag="Kari Coleman" tagKey="5d77682b961905001eb92461" role="Allison" thumb="https://metadata-static.plex.tv/people/5d77682b961905001eb92461.jpg"/>
<Role id="22390" filter="actor=22390" tag="Barney Martin" tagKey="5d7768598718ba001e3196bd" role="Morty Seinfeld" thumb="https://metadata-static.plex.tv/d/people/d8402fbfba9a881d9c544934755049e6.jpg"/>
<Role id="22389" filter="actor=22389" tag="Liz Sheridan" tagKey="5d77682c5af944001f1f7e45" role="Helen Seinfeld" thumb="https://metadata-static.plex.tv/people/5d77682c5af944001f1f7e45.jpg"/>
<Role id="22386" filter="actor=22386" tag="Estelle Harris" tagKey="5d77682985719b001f3a1311" role="Estelle Costanza" thumb="https://metadata-static.plex.tv/8/people/8cad3f911f1c5e9edaf0fe02590df3ac.jpg"/>
<Role id="22382" filter="actor=22382" tag="Ruth Cohen" tagKey="5e16355410faa500400dbf1e" role="Ruthie Cohen" thumb="https://metadata-static.plex.tv/e/people/e2bb56c2a7bd82c8286fc53aca0acb48.jpg"/>
<Chapter id="22743" filter="thumb=22743" tag="Birthdays" index="1" startTimeOffset="300" endTimeOffset="30310" thumb="/library/media/33495/chapterImages/1"/>
<Chapter id="22651" filter="thumb=22651" tag="Break" index="2" startTimeOffset="30310" endTimeOffset="31811" thumb="/library/media/33495/chapterImages/2"/>
<Chapter id="22744" filter="thumb=22744" tag="A journalist hears Elaine make fun of Jerry and George" index="3" startTimeOffset="31811" endTimeOffset="811812" thumb="/library/media/33495/chapterImages/3"/>
<Chapter id="22651" filter="thumb=22651" tag="Break" index="4" startTimeOffset="811812" endTimeOffset="812128" thumb="/library/media/33495/chapterImages/4"/>
<Chapter id="22745" filter="thumb=22745" tag="George tries to use the article to get away from Allison" index="5" startTimeOffset="812128" endTimeOffset="1281130" thumb="/library/media/33495/chapterImages/5"/>
<Chapter id="22651" filter="thumb=22651" tag="Break" index="6" startTimeOffset="1281130" endTimeOffset="1282130" thumb="/library/media/33495/chapterImages/6"/>
<Chapter id="1516" filter="thumb=1516" tag="End Credits" index="7" startTimeOffset="1282130" endTimeOffset="1338340" thumb="/library/media/33495/chapterImages/7"/>
<Marker final="1" id="32157" type="credits" startTimeOffset="1296503" endTimeOffset="1338337">
<Attributes id="32157" version="4"/>
</Marker>
<Extras size="0"> </Extras>
<Related> </Related>
</Video>
</MediaContainer>
Trigger “Refresh Metadata” for the whole Season.
Another thing to check: open the srt file using this software Subtitle Edit
If the “Encoding” selector says anything else than “UTF-8”, switch it to UTF-8. Then press the “Save” icon.
I’ve done it and it’s still the same. Before these updates it worked perfectly.
What updates?
Did you trigger “Refresh Metadata” for the whole Season?
Is R: actually a network file share? If so, do the SRT files have identical access permissions set as the video file?
its works
thanks
