Local Trailer questions (naming and functionality)
I use local trailers exclusively and have a couple of questions about how they should be named to achieve the desired results.
I’ve seen many references to Plex using the “first trailer” as the default trailer. How does Plex determine which trailer is the first one? I would like to be able to designate my default trailer.
When I have multiple trailers, are they supposed to be listed in alphabetical order? If so, why does “TV Spot” come before “Theatrical Trailer”, “Trailer”, “Teaser”, or “Theatrical Teaser”?
If a filename contains quotes “”, Plex displays it as small boxes. What needs to be done to have quotes displayed as quotes?
If I decide to have Plex play trailers before a movie, will it only select from the default trailers in the library, or will it use any trailer I have in the library? If any trailer, is there a process to tag “Red Band” trailers so that they aren’t used?
If it matters, I am running servers on a MacMini and a Synology NAS. Any assistance is appreciated.
