Locked metadata storage file?
Looking around the file system, i found all of the cached metadata, but i can not seem to find where the any modified/locked data is stored.
I have searched some of the forums, but it is not a simple task to find this as the general metadata location is what is found in the search.
any help with this would be appreciated.
so, anyone have any info on this? it's rather annoying to not be able to import this, or be able to write a quick program to modify the into for me when i add new movies, or for the 500+ collection i already have properly tagged...
Why not have a look at the API that is used by the metadata agents.  I also think you will find this in the database not just the filesystem.
