With my PS4 as the hub in my room I use Plex on it to consume my content. Now, every time when I start the Plex app it takes about 1-2 minutes to show the passcode numbers, from where I can insert my passcode. That’s pretty annoying.
The only thing I could possibly relate to being the cause, is that my account is connected to several servers. In any other Plex app (web/ios) I am not experiencing this behaviour though.
Am I on the right track or is something else causing this?
you can set it to auto remmber so you dont have to do a pin code every single time, click your user name top right after your signed in and you should see automatically sign in you can check the box.
Thank you bal3wolf, but that wasn’t my main concern.
Actually, yesterday I figured out what caused it. My server had an option enabled to ‘preferably’ connect through a secured connection. When I disabled it, login-in became super fast.
