Login issues
I know this has been mentioned but it’s honestly bullshit Plex can’t solve these logins issues. It’ll work fine for a short period of time and randomly start up again.
When I use http://127.0.0.1:32400/web/index.html I repeatedly receive the “There was an error signing in” one each time and then it tells me Plex is down for maintence
When I use https://app.plex.tv/desktop everything works just fine. Yes, I’ve entered the password correctly. It’s a bunch of bullshit this continues constantly. Fix your $hit Plex
Hi msullivan1984,
I really appreciate those lovely words, but as a general recommendation, you tend to get more useful replies in less time if you’d use more kind words.
That out of the way, check if you have any firewalls blocking traffic between PMS and Plex. I that is not the case, you can decide if you rather don’t want to log in from your home network at all (access without authorization), you can do that from settings > Network > List of IP addresses and networks that are allowed without auth (advanced), or share the logs so the community can take a look at them and fixyour issue :wink:
