Server Version#: 4.141.0
Player Version#: 4.29.2
I lost a drive with some movies and so I need to know how to delete them from the library so they don’t show up when searching?
The easiest thing would probably be to remove it as a path in your library settings (Manage Library > Edit > Add folders). Before doing that though, if you don’t already have a list of everything that was on that drive, it could be worth using WebTools-NG’s ExportTools or Tautulli’s export guide so you know exactly what you’ll be removing from your libraries.
