So on my plex server it wont remove unavailable file paths. im on a windows 10 machine
my drives are split up into 2 drives one for letters A-M and one for letters N-Z
before it was all on one drive then i split the one drive into A-M so the original drive is still being used but letters N-Z from the original is missing and no matter how many times i scan what settings i turn on or off it wont remove the paths
the top 2 paths is when it was all one drive with letters A-Z the bottom two is now the split drive and is placed under N-Z i want the original drive paths to be removed
“Yes” is not necessarily a helpful answer if there’s different options in question. Also the screenshot isn’t overly helpful here.
IF you have the A-M, N-Z folders under ...\Media\TV\TV\ (or they used to be there with the folders still being linked on your library settings) this could cause this kind of hiccup.
