Thanks, I can see it now.
May 17, 2020 16:48:44.704 [0xe4af8b40] DEBUG - Found session GUID of 4x8qeemzl4xow3fjb3rkepe2 in session start.
May 17, 2020 16:48:44.704 [0xe4af8b40] DEBUG - Cleaning directory for session 4x8qeemzl4xow3fjb3rkepe2 ()
May 17, 2020 16:48:44.704 [0xe4af8b40] DEBUG - Starting a transcode session 4x8qeemzl4xow3fjb3rkepe2 at offset -1.0 (state=3)
May 17, 2020 16:48:44.705 [0xe4af8b40] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
May 17, 2020 16:48:44.705 [0xe4af8b40] INFO - CodecManager: starting EAE at "/tmp/pms-ba85e9e6-4144-4deb-bf27-2cbaf66320e1/EasyAudioEncoder"
May 17, 2020 16:48:44.705 [0xe4af8b40] DEBUG - Job running: '/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-652-linux-x86/EasyAudioEncoder/EasyAudioEncoder'
May 17, 2020 16:48:44.705 [0xe4af8b40] DEBUG - Jobs: Starting child process with pid 4035
May 17, 2020 16:48:44.706 [0xe4af8b40] DEBUG - [Universal] Using local file path instead of URL: /gordon/media/movies/Star.Wars.Episode.IV.A.New.Hope.1977.2160p.BluRay.REMUX.HEVC.TrueHD.7.1.Atmos-FGT/Star.Wars.Episode.IV.A.New.Hope.1977.2160p.BluRay.REMUX.HEVC.TrueHD.7.1.Atmos-FGT.mkv
May 17, 2020 16:48:44.706 [0xe4af8b40] DEBUG - TPU: hardware transcoding: zero-copy support not present
May 17, 2020 16:48:44.706 [0xe4af8b40] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
I see you have a ton of ethernet adapters.
Is this a VM or a container? (the docker bridge is clearly identified)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - Detected primary interface: 192.168.0.155
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - Network interfaces:
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 3 enp3s0 (192.168.0.155) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 4 enp3s0d1 (10.0.0.2) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 5 br-60a6664c3013 (172.19.0.1) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 6 docker0 (172.17.0.1) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 158 br-4a636ca5a94b (172.20.0.1) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 159 br-110d10d6457c (172.30.0.1) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 160 br-5d09f6ea2474 (172.40.0.1) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 1 lo (::1) (loopback: 1)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 3 enp3s0 (2a01:e0a:20b:94a0:202:c9ff:fed2:325c) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 3 enp3s0 (fe80::202:c9ff:fed2:325c%enp3s0) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 4 enp3s0d1 (fe80::202:c9ff:fed2:325d%enp3s0d1) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 6 docker0 (fe80::42:d1ff:fef9:5faa%docker0) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 158 br-4a636ca5a94b (fe80::42:dcff:fe6c:654c%br-4a636ca5a94b) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 159 br-110d10d6457c (fe80::42:12ff:fe91:9f31%br-110d10d6457c) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 160 br-5d09f6ea2474 (fe80::42:2cff:fe86:cdfe%br-5d09f6ea2474) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 162 veth8a31774 (fe80::9824:31ff:fefe:a050%veth8a31774) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 164 vethbd93261 (fe80::ecf8:61ff:fed2:be59%vethbd93261) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 166 veth386033b (fe80::74ee:50ff:fead:b417%veth386033b) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 168 veth49d2b8a (fe80::c000:deff:fefb:4869%veth49d2b8a) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 170 veth38db229 (fe80::a024:8bff:fec0:59ac%veth38db229) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 172 veth3f1b9ed (fe80::5499:96ff:fe52:82e7%veth3f1b9ed) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 174 veth9393f65 (fe80::285a:58ff:feb1:cf9c%veth9393f65) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 176 veth547fa2a (fe80::7ca8:e4ff:fee7:da4%veth547fa2a) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 178 veth8cee418 (fe80::f49d:b8ff:fe12:32e0%veth8cee418) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 180 vethe10234c (fe80::7442:beff:feb2:5d0f%vethe10234c) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 182 vethed4a602 (fe80::301f:6dff:fe47:3737%vethed4a602) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 184 veth6ac5e69 (fe80::8096:c4ff:fe52:813%veth6ac5e69) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 186 vethbc772bc (fe80::80ee:62ff:fe24:a59e%vethbc772bc) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - * 188 vethe7d5f5f (fe80::46b:6eff:fe33:3a4e%vethe7d5f5f) (loopback: 0)
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - Creating NetworkServices singleton.
May 17, 2020 16:47:40.576 [0xf5491700] DEBUG - NetworkServices: Initializing...
