Lots of thumb-xxxx.jpeg files left behind
Server Version#: 1.31.1.6733
Player Version#: 1.31.1.6733
Following an update (I think 2 ago) the C drive on my Plex Server has been filling up. It looks like
C:\Users[…]\AppData\Local\Temp[Guid] is breaking apart my live TV recordings (Hauppauge) into thousands of jpeg files and then not cleaning up. (It looks like about 30 minutes at 25FPS perhaps).
I don’t have any post processing that I’m aware of.
I have disabled any sort of Video Previews as far as I can tell and yet it continues.
Am I missing a setting for something new causing this problem?
I shut Plex Server down, deleted the contents of the temp folder and next day it is back from the overnight recording.,
Any thoughts?
Thanks,
Gary
Are you using 3rd-party anti virus software
or do you use OneDrive software?
Have you enabled ad-detection in your DVR library?
No A/V on this box as it stands on its own VLAN.
No OneDrive as this is it’s only focus
I checked the recordings that made the thumbnails last night (QI) and “Detect Commercials” is disabled. Is there be a system-wide setting that overrides this?
:face_with_raised_eyebrow:
Not to my knowledge, no.
