LyricFind lyrics no longer showing
As title says there is an error with LyricFind lyrics showing. Where the lyric icon is available the box appears with message “There was an error loading the lyrics”. For some tracks there lyric icon is greyed out.
I also did a small test library with LyricFind at the top of the agent list but also no joy.
I am using the lastFM agent and order when I setup the library was “local media assets > last.fm > LyricFind”. I did have PortForwarding on to protect remote access but I have since disabled this. Internet connection is not filtered any other way that I know of.
It would be great if there was a solution to this - I see others have had problems also!
I had the identical problem that was fixed (for me) by upgrading
to the latest version of Plex Media Server. Good Luck.
I keep Plex media server up-to-date, and I’ve had the same problem for a few months now.
The server update worked for me (I thought I had it up to date but had missed the most recent update!).
