Problem with LyricFind “An error occurred loading these lyrics.”
Server Version#: 1.16.3.1402
Player Version#: 3.104.2
I always get the error “An error occurred loading these lyrics.” when I tried to use the “lyric find”-Plugin.
I’ve tried:
  • several times stop server and restart it
  • refresh metada on music libraries
  • several “new libraries” and Rescan and Refresh-Actions. Nothing helped so far.
  • reading lyrics on my apple TV
I upgraded to the last version 1.16.3.1402 yesterday BEFORE upgrade the lyrics was working fine
currently I have small music library of four interprets only - new in plex audio
In logs are some errors in lyrics part but I am not enough trained to understand it
example:
2019-07-31 14:03:02,371 (7f7e7684f700) : DEBUG (model:32) - Loading model with GUID com.plexapp.agents.lastfm://ABBA/Super%20Trouper?lang=en
2019-07-31 14:03:02,372 (7f7e7684f700) : DEBUG (model:234) - Deserializing from /volume1/Plex/Library/Application Support/Plex Media Server/Metadata/Albums/d/4983440af537c77bc9f199095a24749995fbe0d.bundle/Contents/com.plexapp.agents.lastfm/Info.xml
2019-07-31 14:03:02,408 (7f7e7684f700) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/library/metadata/4742/tree’
2019-07-31 14:03:02,414 (7f7e7684f700) : ERROR (networking:219) - Error opening URL ‘http://127.0.0.1:32400/library/metadata/4742/tree’
2019-07-31 14:03:02,415 (7f7e7684f700) : CRITICAL (agentkit:1014) - Exception in the search function of agent named ‘LyricFind’, called with keyword arguments {‘id’: ‘4871’, ‘guid’: ‘com.plexapp.agents.lastfm://ABBA/Super%20Trouper?lang=en’, ‘force’: True, ‘primary_agent’: ‘com.plexapp.agents.lastfm’, ‘parentID’: ‘4742’} (most recent call last):
File “/volume1/@appstore/Plex Media Server/Resources/Plug-ins-22929c8a2/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/agentkit.py”, line 994, in _search
Having Synology DS918+ no problems so far met
Thanks for help
Plex Media Server Logs_2019-07-31_15-42-17.zip (4.0 MB)
small update. Some music start to work
Only Bryan Adams has no lyrics
I unmatched it match again refreshed metadata etc
no result
M
