Server Version#:1.25.2.5319-c43dc0277
Player Version#: Plexamp 3.9.0
How can I get lyrics on Plexamp ?
The lyrics of each song are in .txt format; with the same name as the song in the same folder.
Long press on the track title, while it is playing.
After adding the txt or LRC file, you must refresh metadata of the whole album.
The txt file must use UTF-8 encoding.
That works ! (Long press on the track title)
Thanks so much
Or even tap on the track titles, no need for a long press.
Yes
Does this work with the lyrics pulled from lyric finder? Can never get lyrics to show up on Plexamp, only Plex.
AFAIK, yes.
If you name the lyric files exactly as the song itself (except for the file name extension, of course) and put it beside the song (i.e. not in a subfolder).
You may first have to configure lyric finder to follow that convention.
If you get lyrics on e.g. the Plex web app, you get them in Plexamp as well.
Oh thanks for that. Will try it out.
