The last week I have been unable to see lyrics on Plexamp. It just comes up blank. Is anybody else experiencing this?
Do you have your own lyrics files?
Or are you using Plex’s LyricFind integration?
If the latter, try Refresh Metadata on the affected album. Then inspect the plex media info of a song. If the lyrics are no longer listed, either the metadata agent has an issue, or LyricFind has lost the right to that song lyric.
Possibly just not available in your region. Lyrics for that particular song does not look like avail in the US right now though our provider Lyricfind. https://lyrics.lyricfind.com/lyrics/ice-cube-it-was-a-good-day
It impacts me with any song. That was just one example. It used to work for me always. Now it doesn’t at all. Something broke.
Well then would need to see the app logs to see if there is any errors loading. Do the lyrics not show up in other apps either or just not Plexamp?
I have the same problem and this is the output from logs when asking for lyrics:
Completed: [192.168.10.104:58541] 404 GET /library/streams/231310?format=xml&includeInlineAttribution=1&includeFields=thumbBlurHash (19 live) #1ef59 TLS GZIP 363ms 511 bytes (pipelined: 6)
