M3u music playlist no longer global, each playlist is per library
I have 2 music libraries, and there are m3u playlists in each library.
Up until a recent update, all playlists were visible in Plexamp not matter what library you had selected.
Now the playlists are separated per library, is there setting I can change to make all playlists global?
TIA
Looking at these comments, all playlists should be viewable - >
It will be a setting in the next release.
Perfect, thanks
