After playing any TV Show or Movie Plex player closes and I have to start again. This happening on my Mac Player and I have been searching can’t find any having the same problem.
OK, I have not seen this on my setup.
Can you please specify OS (for PMS and Player) and app versions (of PMS and player)?
MacOs Catalina 10.15.5
Plex for Mac 1.22.0.1421 - be6a7c42
The server is windows 10 latest version and PMS 1.20.4.3517-ab5e1197c
OK, I am:
- Catalina 10.15.7
- Plex for Mac - same as you
- PMS same release as you
I am not seeing this issue and I do not remember the problem when I was on Catalina 10.15.5.
Don’t want to sound dumb but have you tried uninstalling/reinstalling Plex for Mac?
That is the thing how do I uninstall it when I never installed it? All I did was download the app and opened it, never installed it. Do I delete the downloaded app and re-download it?
well then, not installing it may be the problem here.
To “install”, simply move it to the applications folder. Do that and try running it again.
Thanks man for the assistance. It is working, can’t believe it was that simple.
Cheers!
Glad it is working!
