Player Not Displaying anything
Server Version#: 1.18.5.2309-f5213a238
Player Version#: 1.6.3
When I click to open Plex Player on my Mac, the icon bounces but the app doesn’t display. If I click “show all windows” it just displays a blue outline rectangle. This started after MacOs update to 10.15.3.
Any ideas on a fix? I prefer the standalone app to the web app.
Have you tried uninstalling and then reinstalling the app?
Sorry, yes. Uninstall/reinstall. Uninstall/restart/reinstall. Reset SMC and PRAM for good measure. Still doesn’t work.
Same issue here although the beta app works fine. Cannot confirm the link to the OS update, though.
So all is well after removing anything in the library that had to do with Plex (application settings, preferences, etc)
