macOS plex player opens/runs but does not show its window
Server Version#:
Player Version#: (latest on mac) Plex-1.13.0.1275-bbd8d37b-x86_64
It used to be working fine until yesterday. Now nothing opens/shows up when I run the plex media player on my macbook (High sierra)
the options when i click on the plex icon:
after i clicked on show all windows:
@nmik I have the same issue. Same exact issue. I’m also on high sierra. I’ve been waiting for an update but the update was what broke it in the first place. I’m also using an external display and sometimes the resolution configuration is a little wonky when dragging it from display to display, I wonder if that’s part of the issue.
@miniluigi008 Thanks for solidarity! :slight_smile: No one else seems to be affected by this enough to care. Maybe it will be fixed with the next update.
I find this happens to me when I close the app leaving it in full screen mode. If I close full screen before quitting the app, it works.
I usee AppCleaner to uninstall the app and reinstall if I forget to leave full screen by mistake, the only way I found to fix the problem.
I had the same issue as nmik and miniluigi. Used a third-party app uninstaller to remove Plex and all related files, then reinstalled (v1.17.0.1376). Works fine now.
Given that Plex for Mac is an app that is usually used in fullscreen mode, to require users to install and use a third-party uninstaller EVERY TIME you happen to close it while it is in fullscreen mode is one hell of a bug.
Still a problem three months after the original post here. Pity no one at Plex reads these forums.
Chiming in to say that I’m having the same ridiculous issue. I only use the Plex player on this Mac, but it’s the set-top computer, and we use it to drive all of our viewing content…which has mostly shifted over to Plex. It’s been buggy for a couple of months (fullscreen mode breaking upon relaunch libraries/content sometimes inaccessible until a relaunch, and my home page customization randomly being dumped a couple of days ago), but today it finally just won’t show a window.
I have just installed Plex on my Mac and I am having the same issue - does anyone have a fix other then the remove and reinstall?
