Server Version#: 1.14.1
Player Version#:2.25.0.940-485e2ea4
If I customize my Home Screen Media Types in the player app, the list of “show & include” and “hide & don’t include” as well as the list order keep getting reset.
There doesn’t seem to be a pattern for when it gets reset, but it will work fine for a few times and then the saved preferences are reset.
None of the other categories are being affected ie Audio, Video, Subtitles. Just Home Screen Media Types.
Hey folks, thanks for reporting this issue. I’ll file an internal ticket so we can investigate.
Does this mean the save preferences are reset after you close the application and then open it at a later date, or this is happening even while the application is open?
Update: Seems to be unrelated. The non-TV layout settings just reset and the Home Screen Media Types remain unchanged.
One more thing I noticed. When the Home Screen Media Types are reset, all settings for PMP in the non-TV layout also reset to their default values. For example, under PMP -> General, the Time Format resets to 12 hours from 24 hours. Under Quality, Internet Streaming resets to 2 Mbps, etc.
I’ve only noticed the Home Screen Media Types reset when I quit then later re-launch PMP (later could be minutes or hours). I have not noticed it when switching between layouts.
Re: desktop layout settings reset, I’ve definitely noticed it when quitting then relaunching PMP. But not sure about when switching between layouts. I’ll watch for that and let you know if I see anything relevant.
