Macgyver and Macgyver 2016 not in 2 different series
Server Version#: 1.21.3.4046
Player Version#:multiple
I have moved plex from my old server to a new truenas 12.1 and with that the shows that were showing up correctly previously are now incorrect. Specifically when they are 2 shows with the same name but different vintages. For example Macgyver used to be seperated by the 1984 version and the 2016 version. It is now however all under the 1984 version. I am not sure why this is occuring. Any ideas?
Jamie
PMS 1.21.4.4054
Plex combined them into the 2016 version for me. A Split Apart and Fix Match quickly resolved things. Using Plex Web, click on the three vertical dots in the lower right corner of the Show icon/cover art (not at the season or episode levels). Split Apart and Fix Match available in the resulting menu.
Edit: If I Plex Dance the shows, and return the 1984 version first, Plex recognizes the shows correctly (I did not try returning the 2016 version first).
/TV Library
../MacGyver
..../Season 01
....../MacGyver - s01e01.mkv
../MacGyver (2016)
..../Season 01
....../MacGyver (2016) - s01e01.mkv
Hey Thanks so much for the help, The Plex dance didnt work, but the split apart and fix match did the trick.
