The past couple of weeks, when I go into my Recorded TV library and look at the Magnum PI that I recorded, it has the season/episode number correct but Plex is showing me the episode name and description from the 1980 series.
But when I go into the Plex app, into Live TV & DVR, the recording history shows the correct, current series episode name.
Clearly Gracenote has it correct; what is Plex doing to ignore Gracenote’s metadata and use the old series info instead?
Server Version#:
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I went back into the entire show library and saw that the whole library had been mismatched. It must have happened sometime within the past three weeks.
I didn’t have to custom match; I just had to rematch and tell it to use TheTVDB, and it fixed itself.
So the Gracenote data are good, but something went wonky in the library. Huh.
