Maintaining configuration
Server Version#:
Is there a compatibility issue with using the Terramaster F-210 as a Plex media server? I have to go to the web server location of the Nas and click on the Plex icon everyday. The Plex window then says “Configuring…please wait” then the server resumes access. Having to do this daily is unnecessary. Is there a way to make sure it maintains connection?
Hello,
I personally have not had this issue even using the app store version. I recommend you try this - Terra Master TPK Manual Application Install - #3 by chrisallen
Thanks,
Simon.
