Make fade-in/out optional on plexamp?
Simple feature request. Sometimes it sounds nice, sometimes it doesn’t, and it would be nice to make it optional.
Are you talking about the quick fade on pause/resume, or the mixing between tracks? The latter can be globally disabled if you want to via editing server.json (check release notes for 1.0.1).
The mixing between tracks.
I did not know you could do that, I’ll try it out :slight_smile:
