Server Version#: 1.13.9.5439
Player Version#: Plexamp 1.0.5
When I’m playing a playlist of classical music, crossfade seems to be turned on in Plexamp by default.
This is very annoying. (How) can I turn it off?
Thanks!
Thanks!
Thanks OttoKerner.
Can anyone tell me where to find the .json files so I can modify them?
C:\Users\<username>\AppData\Local\Plexamp\Plexamp
Users is a hidden folder, so you might either have to enable the display of hidden files in Windows or simply copy & paste the following path into the adress bar of Windows file explorer:
%LOCALAPPDATA%\Plexamp\Plexamp
