Make it easier to add remote libraries
Just an idea… it is a bit cumbersome to add a remote media server using the
Go to video plug-ins > 'c' (ctx menu) > Add Source http://x.x.x.x:32400/library/sections. Note, do not choose browse just hit enter when selecting <None>.<br />
Note adding remote libraries only work if you don't have enabled Secure Server Access.<br />
method from the wiki. Is this something that can be streamlined? I am thinking it would be a good idea if this functionality could be at the Media Server level. That way, when accessing the media in the frontend it is seamless (ie. remote shows should up in the standard TV and Movies screens).
For example, I currently have a Mac Mini hooked up to my tv/media center, but would also like to get a duplicate experience on my laptop or another pc in the house, without going into a separate plug-in menu.
Thanks you guys for a great product!
I would if I could, I just do not have enough programming experience on mac outside of web development.
