I have shared my Plex Server with a few family members. One of them shared there login info with one of there friends which I want happy about. When you Share access can you share by using a IP Address so it wont get shared to anyone else?? I think Plex should add this to there Manage Library Access Share to IP Only with Email login access… This way using another IP other than the one authorized it wont work…
Any ideas on this thanks.
Moderator Edit: Merged duplicates. @FordGuy61
<Remember to vI have shared my Plex Server with a few family members. One of them shared there login info with one of there friends which I want happy about. When you Share access can you share by using a IP Address so it wont get shared to anyone else?? I think Plex should add this to there Manage Library Access Share to IP Only with Email login access… This way using another IP other than the one authorized it wont work…
Any ideas on this thanks.ote for your own suggestion after you create it>
That is not possible.
You can limit the total number of streams any particular account can stream at the same time in the server’s network settings Remote streams allowed per user. and/or revoke their access to your server.
[Edit] Note this was moved by another mod as I did not realize you made a post in Feature suggestions as well. The “not possible” i mentioned above was only a comment about the current state of things. I have no idea of the technical feasibility or nor do I have an opinion about this as a feature request.
FYI, I’m the mod that moved it. Edited post to reflect that. Apologies if it caused any confusion.
