Managed users not able to sync playlists...
So happy to finally have sync-able playlists, but can anyone else confirm that only the main account can sync playlists to their devices? When I switch to a managed user (family member) the sync option is no longer available…
Just a quick update…even though the sync option does not appear in the same places for managed users as it does for the master account, I have found one place where it is possible to sync a playlist to a manage user’s account.
On the device, while logged in as the managed user, if you browse to the playlist and click on it to display the contents you will see a sync arrow amongst the option icons (Play, Shuffle, Sync, Delete, More). This will bring up the sync dialog box allowing you to sync the playlist to the device, under the managed users account.
So far this is the only way I’ve found to do this for managed users.
