Does anyone know a way to manually add shows to the “TV Shows” .. I have at least 1/2 a dozen folders that are not showing up .. I have done all the tricks of making sure the files are label correctly and stuff like that .. but if you create a library and use the “TV Shows” option they just don’t show up ..
Now if you make a library with the “Other” as the option then they do show up because you set that to show folders .. Kind of a pain as I would have manually match everything together and when you have over 80 tv shows that would take months …
for the advice … I did your first example for some strange reason that worked … Don’t understand why it worked , because I have not had to have a file that deep in the tree in order it to be picked up …
So now I just need to figure out the Expedition Unknown ones and then the amount of folders in the directory will match what is in plex …
