Hi there,
After being hit by the qlocker ransmoware on my Qnap NAS, I reinstalled my NAS and had to start over with my plex server and libraries…
I’ve done this with the very same files, and configuration in my plex libraries, but I’m experiencing some troubles with the tags for my music library.
For the artists : I have a photo when browsing the library but nothing shows up in the picture thumbnail when I try to modify the artist. Also I have absolutely none background for all the artists.
Before my reinstallation, there were many picture in both of these thumbnails, and I juste had to choose the one I wanted.
In the labels thumbnail, everything is empty (style, mood, similar artists…)
And these missing informations are for appromately 99% of my library.
Strangely, I have just a bunch of artists for whom everthing works fine.
So far, I tried
- to update metadatas several times for the last days
- to analyse the whole base
- to delete all the files et paste them back
- to create a second “dummy library”
- to go back to another scanner and another agent than ‘plex music’
- to optimise the database and delete the bundles
And the results are still the same.
If somebody has a clue to force the metadatas tu update, I will appreciate.
Let me know if you need more information.
Server Version#: 1.22.3.4392
Here’s an exemple for band AC/DC, I think it’s famous enough to have some tags
Another exemple, on of the few that works fine : Antonio Pinto
