It’s no longer possible to mark an episode as played/unplayed, change sub or audio from the plex screen on amazon firestick.
Nor is it possible to mark a show, or a season as played/unplayed.
I have no tried with movies bug I guess it could be the same.
Cheers
Server Version#: Version 4.54.5 on synology
Player Version#: Latest as updates are automatic, sometimes starting the upgrade without a “by your leave” in the middle of a playback.
I have noticed the same thing. I have to go to the web client to mark an episode played or unplayed. Is there going to be a fix for this? I am using a Firetv edition Toshiba television
I’m on a 4K firestick with same issues. I can’t reach the episode submenu to mark episodes as watched. I also notice sometimes subtitles won’t load unless you kill the app. Very buggy
Have the same issue with TV Shows on 4K Firestick.
Seems to me to only be when there is a cast list present as it doesn’t highlight the play/resume, mark played/unplayed submenu when you press down from the episode image and then goes to the cast list on a 2nd down press as it should.
