Match does not work for new file
I have added some new movies to my server but the Match function will not recognize. I have tried with title + release date. I have tried using the imdb address but no match found. These are main stream movies that should be an easy match. How can I fix this ?
Please show how the movies are named.
File names. and server logs will help
Plex Documentation → Your Media → Naming & Organizing Your Movie Files
Thanks for the info.
Question: What path is added to the library? It should be H:\Animation. Adding the root folder of a drive, ex: H:\, is not recommended, as doing so can cause problems with Plex.
Suggestions:
  1. Rename and re-organize the movie, adding the release year and placing it in its own folder.
  2. Add the IMDB/TMDB ID to the folder and file name (optional).
  3. Do the same for Despicable Me 2 and 3 if you have those in your library.
  4. Plex Dance the movie after renaming/reorganizing (instead of just re-scanning the library).
H:\Animation <-- folder added to movie library
...\Despicable Me (2010) {imdb-tt1323594} <-- curly braces for ID
......\Despicable Me (2010) {imdb-tt1323594}.mkv
  • Adding the year helps Plex recognize the movie, especially when there are sequels.
  • Adding the IMDB/TMDB ID tells Plex exactly which movie to match.
  • The Plex Dance removes incorrect matching information from the Plex server’s database.
Thanks for the direction. I have never encountered this before. I usually just move the file into the folder and it uploads correctly. I have had to “fix match” a few times. This is also happening with non sequels. Do you know if this is new ? Or just an update
Always add the year.
If you follow Plex naming & organization, it works the vast majority of the time. The further you stray, the greater the chance of running into problems.
Example: Which Lost City?
Example from my server:
O:\movies-hd  <-- not added to any library
...\D <-- added to movie library
......\Despicable Me (2010)\Despicable Me (2010).mkv
......\Despicable Me 2 (2013)\Despicable Me 2 (2013).mkv
......\Despicable Me 3 (2017)\Despicable Me 3 (2017).mkv
...\The_#-L <-- added to movie library
......\The Lost City (2022)\The Lost City (2022).mkv
