Upgraded to plexmediaserver_1.10.1.4602 and the match function no longer appears in the drop down list when you click the the “…” at the bottom right right hand corner of the movie poster. Is there a new way to match movies?
Sure it does…
Match is in t he same place.
Are you logged on as Admin??
Click on the poster first.
then go to the ellipsis ( . . . ) in the upper right area of the pre-play screen.
Thanks for your swift responces:
@jjrjr1 I know where it should be, I am writing because it’s not there and I am logged in correctly.
@OttoKerner I know what to do, I am writing because I cannot do it.
Update: Match suddenly appeared for 1 movie only then disappeared again.
Further update:
I can get the Match command if I select Get Info first. This appears to be a bug.
No, it’s not a bug. Don’t rely on the Match menu item to be there on the main screen.
Go to the preplay screen of the movie, like I wrote above.
