Maximum Amount of Extras per Movie?
I just imported the Movie “Warcraft: The Beginning” into my Plex library.
I use the Plex Pass Extras feature for all my Movies in combination with my own Extras gathered from the original dvd/bd medium.
With all my Other movies this works fine. I would like my library to list my local extras first and then list all the internet extras, unfortunately Plex is sorting it the other way round. Not an issue up untill now.
Is there a maximum number of Extras that can be connected to any given movie?
Cause in the case of Warcraft, Plex is linking 52 Extras and One Trailer to my movie but none of my local extras are showing up
Anyone experienced this and got a solution ready ?
for me it is as you describe it should be… my own local extras first (except there’s an online trailer and I’ve got none). also… I’ve yet to run into a maximum; so far I’m not aware of any constraints.
Interesting that your sort order is the “correct way round”, any Ideas what might be different in my setup ?
I’d guess that getting the sort order right might solve my issue. Even if there is a maximum of extras linkable to one movie, I would rather loose some of the online ones than my own. hmmm
Somehow, after another refresh the local extras appeared.
So i can confirm there is no numerical limit for extras to be linked to a single movie.
I would still like to get the sort order issue solved, nowing now that there has to be a way (thanks tom80H :wink: )
Any hint would be appreciated.
