Maximum of 360 in resolution
Hi, I have a small problem when I use plex on my PC for the TV there is full resolution but when I use my ipad I can reach a maximum of 360 in resolution. anything I can do about it ???
There’s a number of possible causes for what you experience:
  1. Plex considers the stream to be remote and applies a bitrate restriction you set on your server for remote streams
  2. Plex considers the stream to be remote but there’s an issue with the remote access configuration/setup, resulting the stream to go through a Plex relay server (=indirect stream) – those indirect connections have a 1 Mbps bitrate limit (2 Mbps for Plex Pass members)
  3. The connection is local but for some reason you have a really lousy WLAN connection to your iPad
  4. The client cannot play the media as-is and asks your server to transcode it… if the server isn’t powerful enough, it’ll scale the output down until it’s able to do so in realtime.
How does this stream show up in the Now Playing section of the server dashboard in Plex Web? – e.g. local vs. remote vs. indirect; any transcoding?
Exemplary screenshot from the "now playing" section
https://support.plex.tv/articles/200871837-status-and-dashboard/
Hi, 1000 thanks, I’ll give it a try
