Nothing changed! Transcoding is still failing as previously reported, even with the latest plex server version and the latest plex app.
It fails for an a show and for a season, as previously reported.
I never used mobile/cellular internet to sync/download, just local LAN!
I indeed tap to retry, and it starts retrying but fails every time. I can tap 100 times to retry, and it fails 100 times!
I did ran a continuous ping to the intranet plex server ip address on my lan, and it pinged without missing any packets for more than 2 hours. A download of an episode takes about 4-5 minutes tops, when I restart the intranet plex server and it sometimes works for 1 or 2 episodes before starts to fail, so there’s no actual connection being dropped.
I can actually watch a whole 2 hour movie on my phone on my LAN without interruption, even when transcoding on the fly.
I even tried to add my plex server as a “manual connection”, but according to the logs, download/sync keeps trying to use the plex dynamic dns to connect to my intranet server instead of the actual local lan IP address string I’ve add on “manual connection” in the plex app… Why it can’t just use the local IP address and port as I added to the app and download straight from it? Why connect to blablabla.plex.tv to translate to 192.168.10.13 when it could just use 192.168.10.13 as I entered?
Also, if the problem is connection dropping as you stated, why the download doesn’t just resume from where it stopped once the connection is back on? Even if the download started over would be better than just failing and stop doing anything until the user “taps to retry”!!
The plex download service keeps running on my phone as soon as I open plex, so it could very well detect that a download failed in the middle, and just resume/restart when it can ping the server again (when WIFI is back online), instead of stopping and requiring user input!
You have a service running that runs in background to download… why it doesn’t manage the connection dropping/switching automatically? Instead it delegates that workload to the user? what’s the point in that?
Can you imagine if the netflix app kept asking to retry a download everytime one walks off the wifi? They support would be exploding with tons of complains. Instead, their app just automatically checks and retry in case of errors, making sure the download is done correctly, all by itself, without user interaction.
Since my last message, I left the whole 10 seasons of Friends to be downloaded/synced… and checking today, only 30 episodes managed to be downloaded from 270… that’s since Oct 6th!
It only manages to download 1 or 2 sometimes when the plex server is restarted.
I have sent you 3 sets of logs already, from 3 different days, even with different versions of the server and android app… You’re asking me to send you a fourth one? Did you guys made any changes on anything regarding android download at all?
I can’t dedicate time to it right now to capture logs again as you’re requesting, but I’ll do it for the fourth time as soon as I can.
But I’m pretty sure the logs will be exact the same if you guys didn’t change anything, since the behavior I keep seeing is exactly the same.
