@llewi01 said:
Hi there. I have tried everything and I cant get mine to load. It seems to show the plex icon for a second then disappears. Can you help please?
And was the log file written to ? Plex Media Server.log
I am in the plugins folder but there is no framework.bundle or system.bundle files. There is only the .bundle files for the plugins like crackle, syfy, nickjr etc…
Any other places to find these files? any other fixes??
So facing this issue of loading films with 1080p films with DTS or Dolby Digital Audio, where I am stuck on the loading image on both local playing and on chromecast/ipad/iphone.
This topic is about the plex media server application itself getting stuck starting
Please raise a separate topic for your issue and see reporting issues with plex media server support page for how to report problems - link in my signature
bundle resets for core system bundles no longer needed to be fine as from version 0.9.12.5 of plex media server. If you hVe a problem, uninstall plex media server app and download 0.9.15.2 from https://plex.tv/downloads
And install - if you have problems provide logs as described in the reporting issues with plex media server support page
New user here running into this issue (great first startup experience^^).
PlexMediaServer-0.9.15.2.1663-7efd046-OSX, OS X El Capitan 10.11.2
Already tried reinstalling and restarting, server is always saying “Server is starting…” forever. Server Setup in Safari says:
“A problem has been detected with a core component of Plex Media Server. Please visit the forums and provide your logs, as described here.”
So here I am
PlexMediaServer-0.9.15.2.1663-7efd046-OSX, OS X El Capitan 10.11.2Already tried reinstalling and restarting, server is always saying “Server is starting…” forever. Server Setup in Safari says:
So here I am
This error message is output if the core bundles (python modules) that are part of Plex Media Server are not started in time. Causes have been seen to be:
The server log shows an error whilst communicating with the system.bundle
Feb 06, 2016 22:39:48 [0x7000008c4000] DEBUG - Starting plug-in /Applications/Plex Media Server.app/Contents/Resources/Plug-ins-7efd046/System.bundle.
Feb 06, 2016 22:39:48 [0x7000008c4000] DEBUG - [com.plexapp.system] Setting plug-in to always running (daemon mode).
Feb 06, 2016 22:39:48 [0x7000008c4000] DEBUG - Starting file watcher for com.plexapp.system
Feb 06, 2016 22:39:48 [0x7000008c4000] DEBUG - Spawned plug-in com.plexapp.system with PID 1298
Feb 06, 2016 22:39:48 [0x7000008c4000] DEBUG - [com.plexapp.system] Sending command: GET /:/prefixes
Feb 06, 2016 22:39:48 [0x7000008c4000] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Feb 06, 2016 22:39:48 [0x7000008c4000] DEBUG - Stopping [com.plexapp.system].
Feb 06, 2016 22:39:48 [0x7000008c4000] DEBUG - [com.plexapp.system] Killing.
Feb 06, 2016 22:39:48 [0x7000008c4000] ERROR - Error received reading configuration for com.plexapp.system
Do you have any added security product / proxy / vpn running?
Is there a log file named com.plexapp.system.log in PMS Plugin Logs folder within the Logs folder?
@sa2000 No, I do not have any kind of security/proxy/vpn software running. I also do not have com.plexapp.system.log file, the folder PMS Plugin Logs does not even exist.
Any other ideas?
Anybody able to help?
I have the same problem, have used PMS for several years on MacBook Pro and iMac. It started happening while I was at work in Korea so I have waited until now where I know I am not behind a Firewall or Proxy.
No logs are present in Logs folder.
VPN installed but not active.
@willychang said:
I have the same problem, have used PMS for several years on MacBook Pro and iMac. It started happening while I was at work in Korea so I have waited until now where I know I am not behind a Firewall or Proxy.No logs are present in Logs folder.
If there are no logs, you could launch plex media server app in terminal window and see what errors get returned
I am having a similar problem. I have tried a clean install and verified port 32400 is open. Because I cannot get to the server, I can’t get it to generate a log file. I opened com.plexapp.plexmediaserver.plist and, to me, the file looks corrupt. If so, I don’t know how to repair it.
OSX 10.11.3
27in mid 2010 iMac
2.8 GHz i5
@nuclear_monkey said:
I am having a similar problem. I have tried a clean install and verified port 32400 is open. Because I cannot get to the server, I can’t get it to generate a log file. I opened com.plexapp.plexmediaserver.plist and, to me, the file looks corrupt. If so, I don’t know how to repair it.OSX 10.11.3
27in mid 2010 iMac
2.8 GHz i5
Go through an uninstall as described here
https://support.plex.tv/hc/en-us/articles/201941078-Uninstall-Plex-Media-Server
Is your Mac 32-bit or 64-bit?
Well, that didn’t work. Its quite strange in that the server starts, it will stream and transcode, but I cannot change any of the server settings and the media scraper does not work. It seems like a program conflict, but I haven’t installed any new programs since before the server started to hang.
My Mac is 64 bit and I have attached the verbose web log. This is after the clean install, so none of my library files are there.
Well, that didn’t work. Its quite strange in that the server starts, it will stream and transcode, but I cannot change any of the server settings and the media scraper does not work. It seems like a program conflict, but I haven’t installed any new programs since before the server started to hang.My Mac is 64 bit and I have attached the verbose web log. This is after the clean install, so none of my library files are there.
That is the Plex Web App log. It is showing there is a server named Atomic 2
Are you sure there are no server log files when you follow these steps
Using the Finder’s Go menu, select Go To Folder... then enter the following in the dialog box that pops up:
~/Library/Logs/
Unfortunately, I didn’t have the server set to generate a log file before I lost access to its settings. Is there any file I can modify without using the web interface to get the server to generate a log?
No - it generates a log anyway unless it crashes out or there is permissions issue. The setting is only to increase level of logging - but there should be log files anyway regardless of logging level
Starting Plex Media Server in terminal session would identify startup errors and if it crashes
cd /Applications
./Plex\ Media\ Server.app/Contents/MacOS/Plex\ Media\ Server
That worked to generate errors. I also attached a diagnostics that ran yesterday.
Thanks for the log from terminal session and the high cpu crash log
Two things show from these
os.py", line 157, in makedirs
OSError: [Errno 13] Permission denied: '/Users/greggannon/Library/Logs/PMS Plugin Logs'
I suggest initially you look into the permissions errors
Bizarrely enough, I added write permissions to my log file and that cleared up the problem. I ran Disk Warrior about a month ago and that may have mucked up permissions to the file. You have to make the change manually as 10.11.3 Disk Utility does not have a permissions repair option. Thanks for the help!
