Server Version#:1.40.5.8621-836b34c27
I had to reinstall Plex server after resetting my PC. I get the login screen and enter my pin but only get a loading screen. When I try to open Plex Server it will not load. I can get in through the Plex site, but cannot add/update/change anything. My server is no longer showing and there seems to be no way to add it. I removed old devices, only leaving the ones added in the last day or so. Any suggestions?
Notice the link to the new procedure for claiming servers on Windows, which is linked in that post.
Now I am getting the following when I start the Plex server:
It is not showing in the system tray but the server, update service and scripthost processes are running.
Ok, I finally got this working. I had to uninstall Plex Server, reboot, reinstall it and then it went through the setup process and I could add my media. Thanks for your help. It is appreciated.
