Whenever I navigate and play a video file by viewing "By Folder", after the video stops the menu navigation becomes out of sync and I get the "Trailers is unavailable. Try again later" error message. I have to go back to the top level menus to get the menu selections back in sync. This is a recent problem in the past couple months, as this used to work ok. And I don't view "By Folder" very often so I don't experience it much.
Playing videos from "On Deck" and "All Videos" works just fine, after the video stops the selection menu returns to the last position and you can navigate from there with no issues.
See my signature for how to report an issue so we can see about tracking this down, make sure you just create a "High" log that only captures the actual issue.
Also can you clarify by what you mean by out of synch?
Also what would be really helpful, if the issue is reproducible all the time, is if you could find the commit that introduced the issue; the easiest way is to jump back by say 20 commits and if it didn't exist then try 10 commit ago, etc so that it is very quick to find the exact code changes that caused it (this means we can definitely find and fix it).
Your ATV model (2 or 3) and firmware version: ATV 3, Firmware 7.0.1 (6912)
Using iMovie Theater Channel highjack for PlexConnect
The PlexConnect version number: Since I am using Firmware 7.0.1 and iMovie Theater Channel, any commits prior to Sept 21 do not work at all. Any commits after that have my issue.
A detailed description of the issue: If browsing the menus "By Folder", after playing a video file, the menu navigation gets out of sync (selecting anything gives an error) and I have to exit back to the top level PlexConnect menu to restore normal operations.
