I recently rebuilt my HP Proliant Microserver, running Ubuntu, with Raid 5, reinstalled Plex etc and all work fine.
When I try to use PlexConnect it loads as normal and shows me the menu options, but when I go into Movies, and select to play, i get 'An error occurred loading this content'. I get the same error with TV, in fact with all video files.
What does work however, is my music. This plays fine. It's stored in the same top folder as the video, i.e. MEDIA/Music or MEDIA/Movies etc etc
Anyone any ideas?
I have tried having Plex Connect run on both a Mac mini and the server directly, but no change...
Thanks for the reply. I'm signed into MyPlex etc but still no joy. To clarify, when I start trailers on the ATV3 then menus come up, but when I go into the TV section, nothing shows, no Deck, nothing. All I get is the spinning logo like it's searching...but looking on Ubuntu terminal it's scrolling up and doing/getting something.
He is asking you to read the “Read Before Posting” thread stickied at the top of this forum. It lays out the information needed to help with troubleshooting.
I've read that. Also have reinstalled PlexConnect on a different Mac. Reset the ATV to factory defaults and essentially re-installed everything from scratch. Still getting the same problem. When running there doesn't appear to be any errors in Terminal.
I don't see anything in the Readme that explains what might be wrong, although, not a programmer by any means.
When i enter the TV section there are no folders shown and it says Accessing Trailer forever.
In the Movies folder, it does show movies, but none play, with an error message.
I've run a new log after trying to play a movie. Also have 3 pics, the TV screen where it's just searching, a movie info screen and the error I get when trying to play the movie. Problem is they are all over 2mb, how do I get them to you?
