i have a movie split in 2 parts, when i execute the merge command the movie plays incorrectly, first the second part and then the first.
I tried to rename the source files, merge by selecting one or the other file first, but to no avail … whatever it does is still played in reverse order … and I find no way to change the playback order a once joined.
is there any way to do it?
Thank you
Merging is not the same as having 2 parts. When you merge, you get 2 versions of the movie, not a part 1 and part 2. Please split the movie, them use the naming mentioned above to do parts.
it works…
THANK YOU
