Merged files no longer marked
Server Version#: 1.23.6.4881
Player Version#: Web frontend
I just noticed that it is no longer visible in my movies library when a movie consist of 2 different files. There used to be a label before. As I just re-read all my media files and need to sort them, this is a problem because some of them have been merged though they should not (even though they are in different subdirectories. This happens e.g. with movies with more than one part).
Is it possible to make this visible again? I need to go on every movie and see if I can split it or not…not very effective…
There is a filter for “Duplicates”. It shows you all items which are “splittable”.
Ok, next problem: shows a lot of movies duplicate which are indeed one single file. Might be because i switched scanners and have different uids now, but how the hell do i fix that?
Different guids don’t show as duplicates.
The only way I know is a full Plex Dance.
