Server Version#: 1.16.1.1291
Player Version#: N/A
I just added a new television show to my server. However, after inspection I noticed the display aspect ratio is listed in the metadata as 1.85 when it is actually 2.00. I think this is affecting the display of the video on Roku clients.
Here’s the XML output from the metadata:
<Media id=“32250” duration=“2952448” bitrate=“1045” width=“1024” height=“512” aspectRatio=“1.85” audioChannels=“2” audioCodec=“aac” videoCodec=“h264” videoResolution=“576” container=“mp4” videoFrameRate="24p"optimizedForStreaming=“0” audioProfile=“lc” has64bitOffsets=“0” videoProfile=“high”>
<Part accessible=“1” exists=“1” id=“32265” key="/library/parts/32265/1562438809/file.mp4" duration=“2952448” file="/shares/Television/Strange Angel/Season 2/Strange Angel - S02E01 - The Fool.mp4" size="385846712"audioProfile=“lc” container=“mp4” has64bitOffsets=“0” optimizedForStreaming=“0” videoProfile=“high”>
<Stream id=“65432” streamType=“1” default=“1” codec=“h264” index=“0” bitrate=“944” bitDepth=“8” chromaLocation=“left” chromaSubsampling=“4:2:0” frameRate=“24.000” hasScalingMatrix=“0” height=“512” level="31"profile=“high” refFrames=“8” streamIdentifier=“1” width=“1024” displayTitle=“480p (H.264)”/>
Here’s the mediainfo output for the same video:
General
Complete name : Strange Angel - S02E01 - The Fool.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 368 MiB
Duration : 49mn 12s
Overall bit rate : 1 045 Kbps
Writing application : Lavf58.27.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Format settings, GOP : N=1
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 49mn 12s
Bit rate : 944 Kbps
Width : 1 024 pixels
Height : 512 pixels
Display aspect ratio : 2.000
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.075
Stream size : 332 MiB (90%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 49mn 12s
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 33.8 MiB (9%)
