Server Version#: 1.16.5.1554
Brief history of the issue; Metadata will not download. Had this or related issues for a while now., Metadata download is unreliable and intermittent.
Items appear to match correctly, but metadata doesn’t download. No particular reason, progress indicator spins and spins but nothing ever happens. Sometimes information will update without posters or art. Sometimes, everything does download but only after a zillion “refresh metadata” over a 24 hour period.
It appears to be dependent on time of day too. I’m in the UK, it’s more likely to fail later in the day. Past about 9pm you can forget about it which for me suggests a loading issue on a server. Interestingly, manually browsing to the sources of information appears to be successful (i.e, imdb, tvdb.org etc… all up with correct information being shown in a browser.)
Had an issue getting a file to even match (2005 animated film “Robots”) so turned on debugging. Eventually was able to fix through removing the item, cleaning the database, deleting bundles and emptying trash and then re-adding. Item now matches but stuck with same metadata downloading issue. Since I have the debugging turned on thought I’d dig deeper.
Here’s the weird thing for me. in the com.plexapp.agents.imdb.log file, there are entries like “2019-08-31 19:36:22,806 (ea4) : DEBUG (networking:198) - Not caching ‘http://image.tmdb.org/t/p/w154/vYy0Afpj571fVYmw4tLHHRd6Fhy.jpg’ (content type ‘image/jpeg’ not cacheable in Agent plug-ins)”
Now http://image.tmdb.org/t/p/w154/vYy0Afpj571fVYmw4tLHHRd6Fhy.jpg is a real file I can browse to… it’s a movie poster for this movie Robots. There are a few of these links, all to posters and artwork. So the weird thing is, it DOES appear to be requesting and downloading the artwork, posters and I would assume any other metadata… it just doesn’t ever actually appear. Weirdly, while trying to fix the “matching” issue with this file I matched it to a different film and metadata DID (eventually) download.
Since the symptoms are the same as any other time I’ve had this issue, I’m going to guess it’s the same. Metadata and posters do EVENTUALLY download at some random time and this might eventually be the same. because it does work eventually I’m ruling out permissions. I can browse the resources in a browser so I’m ruling our network access and I can see those entries in the Plex log file so I know the Plex server is attempting to download the right stuff.
Issue has persisted for some time and over multiple versions of PMS. Since the problem eventually, randomly goes away for each item it seems like something that should be fixable, but I can’t see what. Log files are attached (I hope)
