Metadata error for TVDB
since yesterday… plex media server doesn’t retrieve metadata from tvdb
Thanks!
True, second that. Since installing the latest beta (the one without a change log, why?) there is no scraping for new media that has been added to the library. Note, I only have TV Shows in Plex, so the only source being used is TVDB.
@limboroger said:
Since installing the latest beta (the one without a change log, why?) …
off topic: in the meantime there’s a release note (simply stating: “no end user facing changes”)
https://forums.plex.tv/discussion/62832/plex-media-server#Comment_1635821
Problem solved !
@warham30 said:
Problem solved !
How?
The problem was from tvdb… api problem … so … it solved the problem …
I see it now. Thanks for the heads up. Glad it works again!
