Metadata for Show Episodes
Plex is not retrieving any episode metadata for this show, only shows up as Episode 1 and so on
Cold Case Files (2017) - TheTVDB.com
If you have it set for TVDB episode order. There seems to be some issue with TVDB ingestion for that show which I have reported. For now if you change the episode order to TheMovieDB it should get it all.
Perfect, Thanks!! :slight_smile:
I suppose it’s not possible to use different fetchers of different shows? is it one or the other?
Moving to TMDB has upset some other shows in particular
Autopsy USA - TheTVDB.com
There is a global selection for the whole library.
This then can be overridden for each single show.
Just edit the show instead of the library.
Thanks, is this the correct area to change?
Then
Or do I change it from here?
This is what Otto mentioned above:
  • Your first set of screenshots is the library setting (default for all shows added to this library)
  • The screenshot from your next post is the „override“ where you can deviate each show from the library default (or apply a more specific order from that show)
Just double checking, 3rd screenshot fixed it
