Server Version#: 1.25.8.5621
Player Version#: 4.69.1
I recently added the Anime series Elemental Gelade (Erementar Gerad) to my server but found that the series title was not properly capitalized (displayed as ‘Elemental gelade’), the content rating displayed as TV-PG instead of TV-14 (library certification country is set to United States), and the episode information was not loaded. I ran a ‘Fix Match’ to confirm that the series was properly matched and also ran ‘Refresh Metadata’, but it made no difference.
All of the metadata fields were unlocked until I locked them to save the manually entered info. The library for my Anime series is a TV Show library with the new Plex TV Series agent being used. All library settings are defaults.
Episode naming uses the following format: ‘Series Title_S01E01_Epsisode Title.mp4’ and this format has worked fine for dozens of TV Shows, Movies, and Anime Series that I already have in my libraries.
I am adding my server logs for Plex Media Scanner Analysis and for Plex Media Server Matcher from the first episode only, since the process is the same for all episodes.
Here are the logs for the Plex Media Scanner Analysis from episode one of Elemental Gelade:
Mar 19, 2022 13:21:47.079 [21896] DEBUG - “C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe” --analyze --log-file-suffix " Analysis" --no-thumbs --item 88656,88657,88658,88659,88660,88661,88662,88663,88664,88665,88666,88667,88668,88669,88670,88671,88672,88673,88674,88675,88676,88677,88678,88679,88680,88681
Mar 19, 2022 13:21:47.079 [24356] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Mar 19, 2022 13:21:47.174 [24356] DEBUG - Analyzing media parts for item 88656 (Episode 1): 145422
Mar 19, 2022 13:21:47.177 [24356] DEBUG - [ID 158378] Media part analysis: F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4
Mar 19, 2022 13:21:47.178 [24356] DEBUG - [MI] Opening input file: “F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4”
Mar 19, 2022 13:21:47.178 [24356] DEBUG - [FFMPEG] - Opening ‘F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4’ for reading
Mar 19, 2022 13:21:47.178 [24356] DEBUG - [FFMPEG] - Setting default whitelist ‘file,crypto,data’
Mar 19, 2022 13:21:47.179 [24356] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Mar 19, 2022 13:21:47.179 [24356] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Mar 19, 2022 13:21:47.180 [24356] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Mar 19, 2022 13:21:47.185 [24356] DEBUG - [FFMPEG] - Processing st: 0, edit list 0 - media time: 0, duration: 123299460
Mar 19, 2022 13:21:47.187 [24356] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Mar 19, 2022 13:21:47.194 [24356] DEBUG - [FFMPEG] - Processing st: 1, edit list 0 - media time: 0, duration: 60409900
Mar 19, 2022 13:21:47.196 [24356] WARN - [FFMPEG] - stream 0, timescale not set
Mar 19, 2022 13:21:47.196 [24356] DEBUG - [FFMPEG] - rfps: 23.916667 0.004905
Mar 19, 2022 13:21:47.196 [24356] DEBUG - [FFMPEG] - rfps: 24.000000 0.000800
Mar 19, 2022 13:21:47.196 [24356] DEBUG - [FFMPEG] - rfps: 24.083333 0.016031
Mar 19, 2022 13:21:47.196 [24356] DEBUG - [FFMPEG] - rfps: 48.000000 0.003201
Mar 19, 2022 13:21:47.196 [24356] DEBUG - [FFMPEG] - rfps: 23.976024 0.000000
Mar 19, 2022 13:21:47.196 [24356] DEBUG - [FFMPEG] - rfps: 47.952048 0.000000
Mar 19, 2022 13:21:47.197 [24356] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1049806 bytes read:1082558 seeks:0 nb_streams:3
Mar 19, 2022 13:21:47.200 [24356] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Mar 19, 2022 13:21:47.200 [24356] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Mar 19, 2022 13:21:47.207 [24356] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 19, 2022 13:21:47.207 [24356] DEBUG - [FFMPEG] - nal_unit_type: 5(IDR), nal_ref_idc: 3
Mar 19, 2022 13:21:47.207 [24356] DEBUG - [FFMPEG] - Format yuv420p chosen by get_format().
Mar 19, 2022 13:21:47.213 [24356] DEBUG - [FFMPEG] - All info found
Mar 19, 2022 13:21:47.213 [24356] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 1050906 bytes read:1082558 seeks:0 frames:3
Mar 19, 2022 13:21:47.214 [24356] DEBUG - [MI] Opening “F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4” for MP4 atom parsing
Mar 19, 2022 13:21:47.214 [24356] DEBUG - Mp4AtomParser: Skipping ftyp atom of size 32 at offset 0
Mar 19, 2022 13:21:47.214 [24356] DEBUG - Mp4AtomParser: Found moov atom of size 1049758 at offset 32
Mar 19, 2022 13:21:47.215 [24356] DEBUG - Mp4AtomParser: Found trak atom of size 397487 at offset 148
Mar 19, 2022 13:21:47.215 [24356] DEBUG - Mp4AtomParser: Found trak atom of size 528533 at offset 397635
Mar 19, 2022 13:21:47.215 [24356] DEBUG - Mp4AtomParser: Found mdia atom of size 397351 at offset 284
Mar 19, 2022 13:21:47.215 [24356] DEBUG - Mp4AtomParser: Found minf atom of size 397266 at offset 369
Mar 19, 2022 13:21:47.215 [24356] DEBUG - Mp4AtomParser: Found stbl atom of size 397202 at offset 433
Mar 19, 2022 13:21:47.215 [24356] DEBUG - Mp4AtomParser: Found mdia atom of size 528374 at offset 397771
Mar 19, 2022 13:21:47.215 [24356] DEBUG - Mp4AtomParser: Found minf atom of size 528289 at offset 397856
Mar 19, 2022 13:21:47.215 [24356] DEBUG - Mp4AtomParser: Found stbl atom of size 528229 at offset 397916
Mar 19, 2022 13:21:47.222 [24356] DEBUG - [MI] * 89e83288919c17e33c141894831b6bdd8861e731 [mp4 h264/aac] Duration: 1369994ms, 656x480 (1.356061) 23.976fps, bitrate=2095kbps, audio channels=2, optimizedForStreaming=1 (“F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4”)
Mar 19, 2022 13:21:47.222 [24356] DEBUG - [MI] Chapters had generic titles, clearing.
Mar 19, 2022 13:21:47.223 [24356] DEBUG - [MI] Closing input file: “F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4”
Mar 19, 2022 13:21:47.223 [24356] DEBUG - Committing media stream changes for part 158378
Mar 19, 2022 13:21:47.224 [24356] DEBUG - Updating media item 145422, size=358800555, metadata_item_id=88656
Mar 19, 2022 13:21:47.224 [24356] DEBUG - Updating part with ID=158378 [F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4]
Mar 19, 2022 13:21:47.225 [22740] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=88656&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Mar 19, 2022 13:21:47.226 [19112] DEBUG - [HttpClient] HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=88656&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Mar 19, 2022 13:21:47.226 [24356] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Mar 19, 2022 13:21:47.226 [24356] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Mar 19, 2022 13:21:47.226 [22740] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=88656&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=idle
Mar 19, 2022 13:21:47.227 [19112] DEBUG - [HttpClient] HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp (reused)
Mar 19, 2022 13:21:47.227 [24356] DEBUG - Updating metadata item (save) () with ID 88656
Mar 19, 2022 13:21:47.227 [19112] DEBUG - [HttpClient] HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=11&metadataItemID=88656&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=idle
Mar 19, 2022 13:21:47.229 [22740] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache?metadataItemID=88654
Mar 19, 2022 13:21:47.229 [19112] DEBUG - [HttpClient] HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache?metadataItemID=88654 (reused)
Here are the logs for the Plex Media Scanner Matcher from episode one of Elemental Gelade:
Mar 19, 2022 13:58:04.800 [1228] DEBUG - “C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe” --match --type 2 --log-file-suffix " Matcher" --item 88655
Mar 19, 2022 13:58:04.800 [9680] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Mar 19, 2022 13:58:04.903 [9680] DEBUG - Matcher: found 0 auxiliary files for Season 1
Mar 19, 2022 13:58:04.910 [9680] DEBUG - [MI] Opening input file: “F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4”
Mar 19, 2022 13:58:04.910 [9680] DEBUG - [FFMPEG] - Opening ‘F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4’ for reading
Mar 19, 2022 13:58:04.910 [9680] DEBUG - [FFMPEG] - Setting default whitelist ‘file,crypto,data’
Mar 19, 2022 13:58:04.910 [9680] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Mar 19, 2022 13:58:04.910 [9680] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Mar 19, 2022 13:58:04.910 [9680] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Mar 19, 2022 13:58:04.912 [9680] DEBUG - [FFMPEG] - Processing st: 0, edit list 0 - media time: 0, duration: 123299460
Mar 19, 2022 13:58:04.913 [9680] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Mar 19, 2022 13:58:04.916 [9680] DEBUG - [FFMPEG] - Processing st: 1, edit list 0 - media time: 0, duration: 60409900
Mar 19, 2022 13:58:04.917 [9680] WARN - [FFMPEG] - stream 0, timescale not set
Mar 19, 2022 13:58:04.917 [9680] DEBUG - [FFMPEG] - rfps: 23.916667 0.004905
Mar 19, 2022 13:58:04.917 [9680] DEBUG - [FFMPEG] - rfps: 24.000000 0.000800
Mar 19, 2022 13:58:04.917 [9680] DEBUG - [FFMPEG] - rfps: 24.083333 0.016031
Mar 19, 2022 13:58:04.917 [9680] DEBUG - [FFMPEG] - rfps: 48.000000 0.003201
Mar 19, 2022 13:58:04.917 [9680] DEBUG - [FFMPEG] - rfps: 23.976024 0.000000
Mar 19, 2022 13:58:04.917 [9680] DEBUG - [FFMPEG] - rfps: 47.952048 0.000000
Mar 19, 2022 13:58:04.917 [9680] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1049806 bytes read:1082558 seeks:0 nb_streams:3
Mar 19, 2022 13:58:04.918 [9680] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Mar 19, 2022 13:58:04.918 [9680] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Mar 19, 2022 13:58:04.920 [9680] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Mar 19, 2022 13:58:04.920 [9680] DEBUG - [FFMPEG] - nal_unit_type: 5(IDR), nal_ref_idc: 3
Mar 19, 2022 13:58:04.920 [9680] DEBUG - [FFMPEG] - Format yuv420p chosen by get_format().
Mar 19, 2022 13:58:04.921 [9680] DEBUG - [FFMPEG] - All info found
Mar 19, 2022 13:58:04.921 [9680] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 1050906 bytes read:1082558 seeks:0 frames:3
Mar 19, 2022 13:58:04.922 [9680] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Mar 19, 2022 13:58:04.922 [9680] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Mar 19, 2022 13:58:04.922 [9680] ERROR - [Time] Date looks invalid: 2019–1–1
Mar 19, 2022 13:58:04.926 [9680] DEBUG - MediaFile: found embedded image, saved to ‘“C:\Users\billy\AppData\Local\Temp\89df80745a26644f88fbe7f1e49732f9.jpg”’
Mar 19, 2022 13:58:04.927 [9680] DEBUG - [MI] Closing input file: “F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4”
Mar 19, 2022 13:58:04.927 [9680] DEBUG - Matcher: no sidecar subtitle files found for F:\Anime Series\Elemental Gelade (2005)\Season 01\Elemental Gelade_S01E01_The Songs of the Sky and Wind.mp4
Does anyone know which websites are being used for TV Series metadata? I’m seeing from Plex that they say it’s pulled from multiple sites, so this seems ambiguous and difficult to identify for making corrections. I’m all for upgrades, but I am also happy to make community improvements in situations like this, so please let me know what I can do to help!
Thank you in advance for assistance and support to resolve this issue.
