Metadata Not Populated on "Update Libraries" from Taskbar
Server Version#: Latest
Player Version#: Latest
Adding a folder/file named “MovieName (2025) {imdb-tt#}”
Update Libraries from Windows Taskbar
Movie image isn’t correct.
Manually “Refresh Metadata” in webapp fixes the problem.
Does it do the same if you choose to scan from the library contextual menu? Jus trying to detemine if issue is with initial scan/update of new file in general or specific to the option in Taskbar.
