Metadata won't load automatically
Server Version#: 1.19.1.2701
Player Version#: 4.22.3
Hi everyone,
I hope you are well and safe.
My Plex Server running on a Synology ds218play fails to load automatically the metadata of my freshly imported movies. I have to go to “Refresh metadata” or sometimes (randomly) “Fix Match” to get them. What bothers me the most is that the poster pictures of my new movies are obviously not displayed (a random frame being shown instead).
Before I manually “Refresh metadata” (in some cases) or “Fix match” (in other cases):
After I manually refresh or fix match (all works perfectly well and official posters are displayed):
My library settings:
My agents settings:
Example of path to a movie: /volume1/vids/films eng/Limitless (2011)/Limitless (2011).mp4
Logs: removed.
What am I doing wrong?
Thanks in advance for your help and take care.
I’d love to help but you turned off DEBUG logging (On by default)
This took away reporting what PMS is actually doing.
It doesn’t save CPU resources nor does it save space. The logs are a fixed size.
When you’ve had the opportunity to
  1. Re-enable DEBUG logging,
  2. Keep VERBOSE logging OFF
  3. Restart PMS
  4. Scan files / Refresh Metadata
  5. Download the logs again after all is completed,
I’ll be able to look again to see what might be happening but there’re no guarantees as the files have already been seen by Plex for that ‘first time’.
Just replying to keep this open because I’m having a very similar problem.
Good morning,
Since im still a noob of the forum i have to “hijack” this thread for some help.
I installed the server spend some days, 2-3 on trying to rename everything (even after adding everything on radarr, so that when media is added it’s renamed), run filebot maybe 3 times until i’m 100% sure nothing is recommended to rename.
I also try to fallow this preparations, that @ChuckPa made :
Restart PMS
And here are the log’s
My question is why is this movie (yes I an at the limite of 1 movie) isn’t add to the library?
Thank you, and after searching this forum, and others, I “know for a fact” that all the awnsers go to "RTFM on how to rename movies for plex), however i know for a fact that this movie can be added to plex without any modification because i have send it to a friend for him to try and he had 0 problems with it.
Thank you for your time, and once more i’m sorry for this (non) topic hijacking.
PS: I have added and removed the server multiple times (>10), removed all files, installed the package from Synology and tried every update the start of this month (3) and right now i’m on the latest version.
I’m sorry but i haven’t made any adicional steps to change the certificate, so my question is how can i change this, or what can i do?
(removing and adding isn’t an option since i made that several times :frowning:
PS: I do get a warning from kasperky when I opened the page the first time after instalation
Ok, so i have done that, also disable kaspersky and i saw two new files beeing generated: ca.crt and certificate.p12
I made the step 4 and 5:
  • Scan files / Refresh Metadata
  • Download the logs again after all is completed,
Nothing changes but it was before you wrote so i notice i shell wait a few minutes before opening plex.
So lets wait, never the less thank you very much @trumpy81at least you could point me to a cause for this.
This all began because only half my media apear.
In the time I wait, setting up a new folder for Movies.
PS: Still get the same erro
The only symptom i have is the files aren’t added to the library:
I have search for the error string you have stated earlier:
 (SSL certificate problem: unable to get local issuer certificate)
And its still there:
May 01, 2020 12:53:16.327 [0x7f4a97a23700] WARN - HTTP error requesting GET https://plex.tv/users/3b521723001b93f0/avatar?c=1587995024 (60, SSL peer certificate or SSH remote key was not OK) (SSL certificate problem: unable to get local issuer certificate)```
What error do you get and where does the error appear?
R: No error apear: like i said the only symptom is the empty (new folder) library
I am still seeing the same certificate error.
R:Yes: I’m still getting tha same kaspersky error on the first acess
Did you try to attach a Gravatar at all?
R:What is a Gravatar ?
No, i belive i have not try to do such thing:
I have make sure that it has, R/O permissions, also trying just before writting with R/W and, refresh both lib and metadata end still no item apears
You are a god,
Between all testing and moving the Subfolders permissions got “lost” as in never changed.
Now shell i worry about the certificate?
Thank you, trumpy81.
Moving my media out of the default video folder was the solution.
Regards.
