MFPlat.DLL issues with Windows 10 Pro N
@“mfzarecky@gmail.com” Thanks for the post!!! Mine is working again!
I made the mistake of using the Windows Insider program to get the latest Windows updates and unfortunately, the Windows Media installer does not work with this newer version of Windows N. Using the provided dll (thanks @timekills ), the server starts and runs again, but Windows reinstalled something over the night that killed it again.
It’s amazing that this one little file is killing so many plex servers!
I will uninstall Windows N and re-install something else if I must but it seems like a drastic solution if the developers can offer some type of workaround. Everything seems to run as expected with the dll put into place.
You rock Timekills! downloaded your file and it worked like a charm
microsoft.com/en-us/software-download/mediafeaturepack
That one solved the problem for me!
“”"> @timekills said:
If you’re willing to trust another person’s file (that person is me, if it matters) I placed my working mfplat.dll file on my web server:
https://www.timekills.org/public/mfplat.zip
I am using Windows Version 1703 (OS Build 15063.674) 64 bit. When I moved this file from my Windows.old into the new c:\windows\syswow64 directory PMS did start working again.“”"
This version of the .DLL file worked for me. Thank a million mate!
I know you posted this more than a year ago, but I just wanted to thank you for your file! I hate changing computers, and something so simple can screw up your whole day… Thanks again!
installing this fixed the issue for me (Windows 10 x64 N)
https://www.microsoft.com/en-us/software-download/mediafeaturepack
Worked for me as well! Thanks!
Fixed my problem ! Thanks !!
Thanks Mr. timekills! this saved my Plex.
This worked like a charm. Thanks!
Only this solved the crash in PMS with hw transcode.
Tried to install Windows_MediaFeaturePack_x64_1903_V1 package on my 1903 Windows 10 but it says not applicable for this computer. So don’t know if it can solve the issue.
Thanks. This just worked!!!
For those of you upgrading to the latest Windows 10 update (1909), they’ve changed how to add the Media Pack feature. Instructions are here:
The Media Feature Pack for N versions of Windows 10 is available for download as an Optional Feature. To install the Media Feature Pack, navigate to Settings > Apps > Apps and Features > Optional Features > Add a Feature, and then locate the Media Feature Pack in the list of available Optional Features.
Note Although you are not prompted to restart your computer, you must restart in order to successfully complete installation of the Media Feature Pack.
Awesome! This worked for me and took minutes and didn’t require a reboot.
Thanks so much!
That worked, thank you for the download.
Thank you mate, your post from 3 years ago fixed my issue. appreciate you still hosting the dll
Fixed my problem too 3y after your post ! Thanks !!
( Windows 10 v1909)
checking in, this STILL works for me running W10N - 4/27/2020
Thanks, timekills!
I had the problem with the mfplat.dll file missing at Plex startup…
Everything is back to normal by simply installing Media Feature Pack from Windows settings.
Media Feature Pack for N versions of Windows 10 is available for download as an Optional Feature. To install the Media Feature Pack, navigate to Settings > Apps > Apps and features > Optional features > Add a feature , and then locate Media Feature Pack in the list of available optional features.
Hope it’ll help
