Mike Judge's Beavis and Butthead
Server Version#:
anyone else having problems with the plex agent finding Mike Judge’s Beavis and Butthead? It only finds the 1993 original. No matter what | do I can’t get it to find the correct title.
thanks
Butt-Head has a hyphen.
Matches fine.
Tried to search again and it doesn’t show up are you using the plex agent?
[mod-edit: fixed screenshot tagging]
how are those files of yours named/organized inside your tv-show library folder?
are you just going with the auto-match when trying to fix-match or have you verified the actual search term in Search Options?
It’s using the naming that sonar uses to download
I also used Mike judge’s Beavis and butt-head under search terms
