Films/TV not "matching" so no metadata at all
Server Version#: 1.16.5.1488 (and previous version)
Player Version#: N/a (web)
New files are being found, but plex is not finding any metadata through the agents and so falls back to the analysis thumbnail. If I do an ‘auto match’, plex just combines the files together with no name, no metadata etc. A manual search for a match comes back with nothing.
Trying to match a film that had worked prior to the latest few PMS updates also returns nothing… I have tried Plex Movie and TMDB for data, same results. The server can see plex.tv and themoviedb.org.
Aug 22, 2019 21:04:18.777 [0x7f35a67fc700] Debug — Auth: authenticated user 1 as Alcedema
Aug 22, 2019 21:04:18.777 [0x7f3597fff700] Debug — Request: [192.168.1.137:53615 (Subnet)] GET /library/metadata/5875/matches?manual=1&title=Alita%3A%20Battle%20Angel&agent=com.plexapp.agents.imdb&year=2019&language=en (13 live) TLS GZIP Signed-in Token (Alcedema)
Aug 22, 2019 21:04:18.783 [0x7f3597fff700] Debug — Issuing search query: http://127.0.0.1:32400/system/agents/search?mediaType=1&id=5875&identifier=com.plexapp.agents.imdb&lang=en&name=Alita%3A%20Battle%20Angel&year=2019&manual=1
Aug 22, 2019 21:04:18.783 [0x7f3597fff700] Debug — HTTP requesting GET http://127.0.0.1:32400/system/agents/search?mediaType=1&id=5875&identifier=com.plexapp.agents.imdb&lang=en&name=Alita%3A%20Battle%20Angel&year=2019&manual=1
Aug 22, 2019 21:04:18.785 [0x7f35a67fc700] Debug — Request: [192.168.1.35:46034 (WAN)] GET /system/agents/search?mediaType=1&id=5875&identifier=com.plexapp.agents.imdb&lang=en&name=Alita%3A%20Battle%20Angel&year=2019&manual=1 (14 live) GZIP Signed-in
Aug 22, 2019 21:04:18.785 [0x7f3597fff700] Debug — HTTP 401 response from GET http://127.0.0.1:32400/system/agents/search?mediaType=1&id=5875&identifier=com.plexapp.agents.imdb&lang=en&name=Alita%3A%20Battle%20Angel&year=2019&manual=1
Aug 22, 2019 21:04:18.785 [0x7f35a67fc700] Debug — Completed: [192.168.1.35:46034] 401 GET /system/agents/search?mediaType=1&id=5875&identifier=com.plexapp.agents.imdb&lang=en&name=Alita%3A%20Battle%20Angel&year=2019&manual=1 (14 live) GZIP 0ms 357 bytes
Aug 22, 2019 21:04:18.785 [0x7f3597fff700] Debug — -1: ()
Aug 22, 2019 21:04:18.786 [0x7f35a67fc700] Debug — Completed: [192.168.1.137:53615] 200 GET /library/metadata/5875/matches?manual=1&title=Alita%3A%20Battle%20Angel&agent=com.plexapp.agents.imdb&year=2019&language=en (13 live) TLS GZIP 8ms 593 bytes (pipelined: 3)
What in the wide wide world of sports kind of name is that? If it is Alita, use the name it has in IMDB - Alita Battle Angel (2019)
That’s all you have to do.
Like I said, it is doing it for all, that was merely an example. No results come back for any film or episode no matter what it is called.
Change your agent to IMDB
diasble IPv6 in your internert adapter
Try the name I gave you (with the date) as the file name instead of the garbage you have now.
Before everyone starts changing agents, May I see some of the directory structure and file names in use?
I ask this because if the naming isn’t good, no agent will match anything.
Remove the colon : and try again. I think that is screwing up the search
The Alita film was one Plex had already matched, I used it as an example…
Here’s a simpler one:
Location: /media/4tb/Movies/Inception (2010)/Inception (2010).mkv
Aug 23, 2019 06:20:06.420 [0x7f2b84cbb700] Debug — Auth: authenticated user 1 as Alcedema
Aug 23, 2019 06:20:06.421 [0x7f2b7f7fe700] Debug — Request: [192.168.1.137:58457 (Subnet)] GET /library/metadata/6177?includeExternalMedia=1&Accept-Language=en-GB&includeConcerts=1&includeExtras=1&includeOnDeck=1&includePopularLeaves=1&includePreferences=1&includeChapters=1&includeStations=1&includeExternalMedia=1&asyncAugmentMetadata=1&asyncCheckFiles=1&asyncRefreshAnalysis=1&asyncRefreshLocalMediaAgent=1 (10 live) TLS GZIP Signed-in Token (Alcedema)
Aug 23, 2019 06:20:06.422 [0x7f2b7ffff700] Debug — Auth: authenticated user 1 as Alcedema
Aug 23, 2019 06:20:06.423 [0x7f2b7e7fc700] Debug — Request: [192.168.1.137:58455 (Subnet)] GET /hubs/metadata/6177/related?excludeFields=summary&includeExternalMedia=1&includeExternalMetadata=1&asyncAugmentMetadata=1 (10 live) TLS GZIP Signed-in Token (Alcedema)
Aug 23, 2019 06:20:06.431 [0x7f2b7f7fe700] Debug — We're going to try to auto-select an audio stream for account 1.
Aug 23, 2019 06:20:06.431 [0x7f2b7f7fe700] Debug — Selecting best audio stream for part ID 6206 (autoselect: 1 language: en)
Aug 23, 2019 06:20:06.431 [0x7f2b7f7fe700] Debug — We're going to try to auto-select a subtitle.
Aug 23, 2019 06:20:06.431 [0x7f2b7f7fe700] Debug — Audio Stream: 19036, Subtitle Stream: -1
Aug 23, 2019 06:20:06.432 [0x7f2b84cbb700] Debug — Completed: [192.168.1.137:58455] 200 GET /hubs/metadata/6177/related?excludeFields=summary&includeExternalMedia=1&includeExternalMetadata=1&asyncAugmentMetadata=1 (10 live) TLS GZIP 9ms 552 bytes (pipelined: 15)
Aug 23, 2019 06:20:06.459 [0x7f2b7f7fe700] Debug — Activity: registered new activity ba30caf9-cdb8-4341-b73a-64f9bc2a8303 - Refreshing
Aug 23, 2019 06:20:06.459 [0x7f2b7dffb700] Debug — Activity: updated activity ba30caf9-cdb8-4341-b73a-64f9bc2a8303 - completed 0.000000% - Refreshing
Aug 23, 2019 06:20:06.460 [0x7f2b7ffff700] Debug — Completed: [192.168.1.137:58457] 200 GET /library/metadata/6177?includeExternalMedia=1&Accept-Language=en-GB&includeConcerts=1&includeExtras=1&includeOnDeck=1&includePopularLeaves=1&includePreferences=1&includeChapters=1&includeStations=1&includeExternalMedia=1&asyncAugmentMetadata=1&asyncCheckFiles=1&asyncRefreshAnalysis=1&asyncRefreshLocalMediaAgent=1 (10 live) TLS GZIP 39ms 1922 bytes (pipelined: 20)
Aug 23, 2019 06:20:06.462 [0x7f2b7dffb700] Debug — Activity: updated activity ba30caf9-cdb8-4341-b73a-64f9bc2a8303 - completed 25.000000% - Refreshing
Aug 23, 2019 06:20:06.462 [0x7f2b7dffb700] Debug — Last refresh (1900-01-01 00:00:00) appears to be older than directory change time (2019-08-23 06:19:13), need to refresh local media agent.
Aug 23, 2019 06:20:06.462 [0x7f2b7dffb700] Debug — Refreshing GUID: 'local://6177'
Aug 23, 2019 06:20:06.463 [0x7f2b7dffb700] Debug — HTTP requesting GET http://127.0.0.1:32400/system/agents/update?mediaType=1&force=1&guid=local%3A%2F%2F6177&id=6177&agent=com.plexapp.agents.localmedia&async=0
Aug 23, 2019 06:20:06.465 [0x7f2b7ffff700] Debug — Request: [192.168.1.35:41656 (WAN)] GET /system/agents/update?mediaType=1&force=1&guid=local%3A%2F%2F6177&id=6177&agent=com.plexapp.agents.localmedia&async=0 (11 live) GZIP Signed-in
Aug 23, 2019 06:20:06.466 [0x7f2b7ffff700] Debug — Completed: [192.168.1.35:41656] 401 GET /system/agents/update?mediaType=1&force=1&guid=local%3A%2F%2F6177&id=6177&agent=com.plexapp.agents.localmedia&async=0 (11 live) GZIP 0ms 357 bytes
Aug 23, 2019 06:20:06.466 [0x7f2b7dffb700] Debug — HTTP 401 response from GET http://127.0.0.1:32400/system/agents/update?mediaType=1&force=1&guid=local%3A%2F%2F6177&id=6177&agent=com.plexapp.agents.localmedia&async=0
Aug 23, 2019 06:20:06.466 [0x7f2b7dffb700] Error — Error response for update:  ().
Aug 23, 2019 06:20:06.466 [0x7f2b7dffb700] Debug — Activity: updated activity ba30caf9-cdb8-4341-b73a-64f9bc2a8303 - completed 50.000000% - Refreshing
Aug 23, 2019 06:20:06.466 [0x7f2b7dffb700] Debug — Activity: Ended activity ba30caf9-cdb8-4341-b73a-64f9bc2a8303.
Aug 23, 2019 06:20:06.524 [0x7f2b84cbb700] Debug — Auth: authenticated user 1 as Alcedema
Aug 23, 2019 06:20:06.524 [0x7f2b7e7fc700] Debug — Request: [192.168.1.137:58457 (Subnet)] GET /library/metadata/augmentations/174?excludeFields=summary&wait=1 (10 live) TLS GZIP Signed-in Token (Alcedema)
Aug 23, 2019 06:20:06.526 [0x7f2b84cbb700] Debug — Completed: [192.168.1.137:58457] 200 GET /library/metadata/augmentations/174?excludeFields=summary&wait=1 (10 live) TLS GZIP 1ms 429 bytes (pipelined: 21)
Aug 23, 2019 06:20:06.692 [0x7f2b84cbb700] Debug — Auth: authenticated user 1 as Alcedema
Aug 23, 2019 06:20:06.692 [0x7f2b1effd700] Debug — Request: [192.168.1.137:58457 (Subnet)] GET /photo/:/transcode?width=180&height=270&minSize=1&upscale=1&url=%2Flibrary%2Fmetadata%2F6177%2Fthumb%2F1566537559%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx (10 live) TLS GZIP Signed-in Token (Alcedema)
Aug 23, 2019 06:20:06.693 [0x7f2b1effd700] Debug — Photo transcoder: Request for url [/library/metadata/6177/thumb/1566537559?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx] (is local: 1 upscaled: 1)
Aug 23, 2019 06:20:06.694 [0x7f2b1effd700] Debug — The cache file did not exist, but the original did [/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/2f/2fc4120008bd5120d788ca1ff339011b24f5f301.jpg].
Aug 23, 2019 06:20:06.708 [0x7f2b7ffff700] Debug — Auth: authenticated user 1 as Alcedema
Aug 23, 2019 06:20:06.708 [0x7f2b7f7fe700] Debug — Request: [192.168.1.137:58455 (Subnet)] GET /photo/:/transcode?width=640&height=293&opacity=30&background=36383b&format=png&blur=47&minSize=1&upscale=1&url=%2Flibrary%2Fmetadata%2F6177%2Fthumb%2F1566537559%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx (10 live) TLS GZIP Signed-in Token (Alcedema)
Aug 23, 2019 06:20:06.708 [0x7f2b7f7fe700] Debug — Photo transcoder: Request for url [/library/metadata/6177/thumb/1566537559?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx] (is local: 1 upscaled: 1)
Aug 23, 2019 06:20:06.709 [0x7f2b7f7fe700] Debug — The cache file did not exist, but the original did [/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/2f/2fc4120008bd5120d788ca1ff339011b24f5f301.jpg].
Aug 23, 2019 06:20:06.712 [0x7f2b1effd700] Debug — Created thumbnail of size 648x270, has pixels: 1
Aug 23, 2019 06:20:06.722 [0x7f2b7ffff700] Debug — Completed: [192.168.1.137:58457] 200 GET /photo/:/transcode?width=180&height=270&minSize=1&upscale=1&url=%2Flibrary%2Fmetadata%2F6177%2Fthumb%2F1566537559%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx (10 live) TLS GZIP 29ms 16842 bytes (pipelined: 22)
Aug 23, 2019 06:20:06.726 [0x7f2b7f7fe700] Debug — Created thumbnail of size 703x293, has pixels: 1
Aug 23, 2019 06:20:06.754 [0x7f2b7ffff700] Debug — Completed: [192.168.1.137:58455] 200 GET /photo/:/transcode?width=640&height=293&opacity=30&background=36383b&format=png&blur=47&minSize=1&upscale=1&url=%2Flibrary%2Fmetadata%2F6177%2Fthumb%2F1566537559%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx (10 live) TLS GZIP 45ms 29042 bytes (pipelined: 16)
Aug 23, 2019 06:20:08.946 [0x7f2b63fff700] Debug — BPQ: deferring onLibraryChanged callback, only 49 seconds since last library change
Aug 23, 2019 06:20:09.301 [0x7f2b84cbb700] Debug — Auth: authenticated user 1 as Alcedema
Aug 23, 2019 06:20:09.302 [0x7f2b7e7fc700] Debug — Request: [192.168.1.137:58455 (Subnet)] GET /system/agents?mediaType=1 (10 live) TLS GZIP Signed-in Token (Alcedema)
Aug 23, 2019 06:20:09.303 [0x7f2b7e7fc700] Debug — [com.plexapp.system] Sending command over HTTP (GET): /system/agents?mediaType=1
Aug 23, 2019 06:20:09.303 [0x7f2b7e7fc700] Debug — HTTP requesting GET http://127.0.0.1:41273/system/agents?mediaType=1
Aug 23, 2019 06:20:09.313 [0x7f2b7e7fc700] Debug — HTTP 200 response from GET http://127.0.0.1:41273/system/agents?mediaType=1
Aug 23, 2019 06:20:09.314 [0x7f2b7e7fc700] Debug — [com.plexapp.system] HTTP reply status 200, with 1992 bytes of content.
Aug 23, 2019 06:20:09.314 [0x7f2b84cbb700] Debug — Completed: [192.168.1.137:58455] 200 GET /system/agents?mediaType=1 (10 live) TLS GZIP 12ms 940 bytes (pipelined: 17)
Aug 23, 2019 06:20:09.332 [0x7f2b84cbb700] Debug — Auth: authenticated user 1 as Alcedema
Aug 23, 2019 06:20:09.333 [0x7f2b7f7fe700] Debug — Request: [192.168.1.137:58457 (Subnet)] GET /library/metadata/6177/matches?manual=1 (10 live) TLS GZIP Signed-in Token (Alcedema)
Aug 23, 2019 06:20:09.339 [0x7f2b7f7fe700] Debug — Issuing search query: http://127.0.0.1:32400/system/agents/search?mediaType=1&id=6177&identifier=com.plexapp.agents.imdb&duration=8888308&filename=%252Fmedia%252F4tb%252FMovies%252FInception%2520(2010)%252FInception%2520(2010)%252Emkv&lang=en&openSubtitlesHash=84a24cb08fd9765b&plexHash=8b35a535fa606db414dcc7c75df7f56365a54a08&name=Inception&year=2010&manual=1
Aug 23, 2019 06:20:09.340 [0x7f2b7f7fe700] Debug — HTTP requesting GET http://127.0.0.1:32400/system/agents/search?mediaType=1&id=6177&identifier=com.plexapp.agents.imdb&duration=8888308&filename=%252Fmedia%252F4tb%252FMovies%252FInception%2520(2010)%252FInception%2520(2010)%252Emkv&lang=en&openSubtitlesHash=84a24cb08fd9765b&plexHash=8b35a535fa606db414dcc7c75df7f56365a54a08&name=Inception&year=2010&manual=1
Aug 23, 2019 06:20:09.340 [0x7f2b84cbb700] Debug — Request: [192.168.1.35:41660 (WAN)] GET /system/agents/search?mediaType=1&id=6177&identifier=com.plexapp.agents.imdb&duration=8888308&filename=%252Fmedia%252F4tb%252FMovies%252FInception%2520(2010)%252FInception%2520(2010)%252Emkv&lang=en&openSubtitlesHash=84a24cb08fd9765b&plexHash=8b35a535fa606db414dcc7c75df7f56365a54a08&name=Inception&year=2010&manual=1 (11 live) GZIP Signed-in
Aug 23, 2019 06:20:09.341 [0x7f2b7f7fe700] Debug — HTTP 401 response from GET http://127.0.0.1:32400/system/agents/search?mediaType=1&id=6177&identifier=com.plexapp.agents.imdb&duration=8888308&filename=%252Fmedia%252F4tb%252FMovies%252FInception%2520(2010)%252FInception%2520(2010)%252Emkv&lang=en&openSubtitlesHash=84a24cb08fd9765b&plexHash=8b35a535fa606db414dcc7c75df7f56365a54a08&name=Inception&year=2010&manual=1
Aug 23, 2019 06:20:09.341 [0x7f2b84cbb700] Debug — Completed: [192.168.1.35:41660] 401 GET /system/agents/search?mediaType=1&id=6177&identifier=com.plexapp.agents.imdb&duration=8888308&filename=%252Fmedia%252F4tb%252FMovies%252FInception%2520(2010)%252FInception%2520(2010)%252Emkv&lang=en&openSubtitlesHash=84a24cb08fd9765b&plexHash=8b35a535fa606db414dcc7c75df7f56365a54a08&name=Inception&year=2010&manual=1 (11 live) GZIP 0ms 357 bytes
Aug 23, 2019 06:20:09.341 [0x7f2b7f7fe700] Debug —  -1:  ()
Aug 23, 2019 06:20:09.341 [0x7f2b84cbb700] Debug — Completed: [192.168.1.137:58457] 200 GET /library/metadata/6177/matches?manual=1 (10 live) TLS GZIP 8ms 596 bytes (pipelined: 23)
Mine is currently the same. Every media file has stopped auto matching. Can’t manual match either. Even after changing agents. It was fine a couple of days ago.
Does the IMDB log show any errors ( it is in the plugins log folder )
No errors, actually shows nothing regarding IMDB requests, just the logs of the plugin initialising a couple of days ago (I replicated the problem just prior to checking these logs).
2019-08-22 22:01:58,602 (7f2e86592700) :  INFO (core:349) - Starting framework core - Version: 2.6.3, Build: 1e5ff71 (Wed Aug 21 06:45:59 UTC 2019)
2019-08-22 22:01:58,602 (7f2e86592700) :  DEBUG (core:361) - Using the elevated policy
2019-08-22 22:01:58,602 (7f2e86592700) :  DEBUG (core:450) - Starting runtime component.
2019-08-22 22:01:58,604 (7f2e86592700) :  DEBUG (core:450) - Starting caching component.
2019-08-22 22:01:58,605 (7f2e86592700) :  DEBUG (core:450) - Starting data component.
2019-08-22 22:01:58,605 (7f2e86592700) :  DEBUG (core:450) - Starting networking component.
2019-08-22 22:01:58,605 (7f2e86592700) :  DEBUG (networking:284) - Loaded HTTP cookies
2019-08-22 22:01:58,607 (7f2e86592700) :  DEBUG (networking:452) - Setting the default network timeout to 20.0
2019-08-22 22:01:58,607 (7f2e86592700) :  DEBUG (core:450) - Starting localization component.
2019-08-22 22:01:58,608 (7f2e86592700) :  INFO (localization:409) - Setting the default locale to en-us
2019-08-22 22:01:58,608 (7f2e86592700) :  DEBUG (core:450) - Starting messaging component.
2019-08-22 22:01:58,608 (7f2e86592700) :  DEBUG (core:450) - Starting debugging component.
2019-08-22 22:01:58,609 (7f2e86592700) :  DEBUG (core:450) - Starting services component.
2019-08-22 22:01:58,609 (7f2e667fc700) :  DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.agents.imdb'
2019-08-22 22:01:58,609 (7f2e86592700) :  DEBUG (core:450) - Starting myplex component.
2019-08-22 22:01:58,610 (7f2e86592700) :  DEBUG (core:450) - Starting notifications component.
2019-08-22 22:01:58,851 (7f2e86592700) :  DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.agents.imdb in namespace 'metadata'
2019-08-22 22:01:58,858 (7f2e86592700) :  DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
2019-08-22 22:01:58,881 (7f2e667fc700) :  DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2019-08-22 22:01:58,882 (7f2e86592700) :  DEBUG (runtime:1117) - Created a thread named 'load_all_services'
2019-08-22 22:01:58,883 (7f2e667fc700) :  DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'
2019-08-22 22:01:58,883 (7f2e86592700) :  DEBUG (runtime:1117) - Created a thread named 'get_server_info'
2019-08-22 22:01:58,884 (7f2e6577a700) :  DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400'
2019-08-22 22:01:58,884 (7f2e86592700) :  DEBUG (core:150) - Finished starting framework core
2019-08-22 22:01:58,885 (7f2e86592700) :  DEBUG (core:560) - Loading plug-in code
2019-08-22 22:01:59,083 (7f2e6577a700) :  DEBUG (core:538) - Machine identifier is 2d070e8d4c3698af5ea81dc68574860e7efa2fdf
2019-08-22 22:01:59,084 (7f2e6577a700) :  DEBUG (core:539) - Server version is 1.16.5.1554-1e5ff713d
2019-08-22 22:01:59,656 (7f2e667fc700) :  DEBUG (services:362) - Loaded services
2019-08-22 22:01:59,709 (7f2e65f7b700) :  DEBUG (services:438) - No shared code to load
2019-08-22 22:01:59,898 (7f2e86592700) :  DEBUG (core:566) - Finished loading plug-in code
2019-08-22 22:02:00,082 (7f2e86592700) :  DEBUG (agentkit:1115) - Creating new agent class called PlexMovieAgent
2019-08-22 22:02:00,083 (7f2e86592700) :  DEBUG (agentkit:933) - Updating agent information: [{'media_types': ['Movie'], 'accepts_from': ['com.plexapp.agents.localmedia'], 'fallback_agent': None, 'contributes_to': ['com.plexapp.agents.themoviedb'], 'languages': ['en', 'sv', 'fr', 'es', 'nl', 'de', 'it', 'da', 'ar', 'ca', 'zh', 'cs', 'et', 'fi', 'el', 'he', 'hi', 'hu', 'id', 'ja', 'ko', 'lv', 'no', 'fa', 'pl', 'pt', 'ro', 'ru', 'sk', 'th', 'tr', 'uk', 'vi'], 'persist_stored_files': True, 'version': 0, 'primary_provider': True, 'prefs': True, 'name': 'Plex Movie'}]
2019-08-22 22:02:00,084 (7f2e86592700) :  DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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_'
2019-08-22 22:02:00,099 (7f2e86592700) :  INFO (core:611) - Started plug-in
2019-08-22 22:02:00,100 (7f2e86592700) :  DEBUG (socketinterface:160) - Starting socket server
2019-08-22 22:02:00,101 (7f2e86592700) :  DEBUG (runtime:1117) - Created a thread named 'start'
2019-08-22 22:02:00,101 (7f2e86592700) :  INFO (socketinterface:184) - Socket server started on port 41653
2019-08-22 22:02:00,102 (7f2e86592700) :  INFO (pipeinterface:25) - Entering run loop
2019-08-22 22:02:00,102 (7f2e86592700) :  DEBUG (runtime:717) - Handling request GET /:/prefixes
2019-08-22 22:02:00,105 (7f2e86592700) :  DEBUG (runtime:814) - Found route matching /:/prefixes
2019-08-22 22:02:00,106 (7f2e86592700) :  DEBUG (runtime:924) - Response: [200] MediaContainer, 148 bytes
2019-08-22 22:02:00,108 (7f2e667fc700) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.imdb/prefs
2019-08-22 22:02:00,126 (7f2e667fc700) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.agents.imdb/prefs
2019-08-22 22:02:00,127 (7f2e667fc700) :  DEBUG (preferences:258) - Loaded preferences from DefaultPrefs.json
2019-08-22 22:02:00,128 (7f2e667fc700) :  DEBUG (preferences:178) - Loaded the user preferences for com.plexapp.agents.imdb
2019-08-22 22:02:00,133 (7f2e667fc700) :  DEBUG (runtime:88) - Sending packed state data (104 bytes)
2019-08-22 22:02:00,133 (7f2e667fc700) :  DEBUG (runtime:924) - Response: [200] MediaContainer, 2223 bytes
Since installing Version 1.16.6.1592 I’ve had an odd problem with new movie matching.
Tried the searches using the different agents but my title line was the default pulled from the file name. Name of file inception.2010.mkv the Match function was able to be selected and then Search Options, it would show in the Title box ‘Inception 2010’ and would not find a single match with PMDB or TMDB.
Default
If I deleted the year from the title box so it would be ‘Inception’ only and both with and without year in the Year box it would find and list the matches for both PM&TMDB
Year%20Move
from the com.plexapp.agents.themoviedb.log
> 2019-09-12 22:03:12,696 (7f4bc6ab4700) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.themoviedb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo2CnMyCmVuczQKbGFuZ2IxczYKbWFudWFsYjFzNwpwcmltYXJ5aTAKczcKdmVyc2lvbnIxCnM2Cmt3YXJnc3M1Ck1vdmllczEwCm1lZGlhX3R5cGUzCnM1CjQ0NjMzczIKaWRzMTQKSW5jZXB0aW9uIDIwMTBzNApuYW1lbnM0CnllYXJyMAo_
> 2019-09-12 22:03:12,699 (7f4bc6ab4700) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
> 2019-09-12 22:03:12,703 (7f4bc6ab4700) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.agents.themoviedb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo2CnMyCmVuczQKbGFuZ2IxczYKbWFudWFsYjFzNwpwcmltYXJ5aTAKczcKdmVyc2lvbnIxCnM2Cmt3YXJnc3M1Ck1vdmllczEwCm1lZGlhX3R5cGUzCnM1CjQ0NjMzczIKaWRzMTQKSW5jZXB0aW9uIDIwMTBzNApuYW1lbnM0CnllYXJyMAo_
> 2019-09-12 22:03:12,705 (7f4bc6ab4700) :  INFO (agentkit:957) - Searching for matches for {'year': None, 'id': '44633', 'name': 'Inception 2010'}
> 2019-09-12 22:03:12,707 (7f4bc6ab4700) :  DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/library/metadata/44633/tree'
> 2019-09-12 22:03:12,741 (7f4bc6ab4700) :  DEBUG (networking:161) - Fetching 'http://127.0.0.1:32400/services/tmdb?uri=%2Fsearch%2Fmovie%3Fquery%3DInception%2B2010%26year%3D%26language%3Den%26include_adult%3Dtrue' from the HTTP cache
> 2019-09-12 22:03:12,760 (7f4bc6ab4700) :  DEBUG (runtime:88) - Sending packed state data (110 bytes)
> 2019-09-12 22:03:12,761 (7f4bc6ab4700) :  DEBUG (runtime:924) - Response: [200] str, 320 bytes
> 2019-09-12 22:04:24,365 (7f4bc6ab4700) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.themoviedb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo2CnMyCmVuczQKbGFuZ2IxczYKbWFudWFsYjFzNwpwcmltYXJ5aTAKczcKdmVyc2lvbnIxCnM2Cmt3YXJnc3M1Ck1vdmllczEwCm1lZGlhX3R5cGUzCnM1CjQ0NjMzczIKaWRzOQpJbmNlcHRpb25zNApuYW1lczQKMjAxMHM0CnllYXJyMAo_
> 2019-09-12 22:04:24,368 (7f4bc6ab4700) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
> 2019-09-12 22:04:24,373 (7f4bc6ab4700) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.agents.themoviedb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo2CnMyCmVuczQKbGFuZ2IxczYKbWFudWFsYjFzNwpwcmltYXJ5aTAKczcKdmVyc2lvbnIxCnM2Cmt3YXJnc3M1Ck1vdmllczEwCm1lZGlhX3R5cGUzCnM1CjQ0NjMzczIKaWRzOQpJbmNlcHRpb25zNApuYW1lczQKMjAxMHM0CnllYXJyMAo_
> 2019-09-12 22:04:24,374 (7f4bc6ab4700) :  INFO (agentkit:957) - Searching for matches for {'year': '2010', 'id': '44633', 'name': 'Inception'}
> 2019-09-12 22:04:24,376 (7f4bc6ab4700) :  DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/library/metadata/44633/tree'
> 2019-09-12 22:04:24,406 (7f4bc6ab4700) :  DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/services/tmdb?uri=%2Fsearch%2Fmovie%3Fquery%3DInception%26year%3D2010%26language%3Den%26include_adult%3Dtrue'
> 2019-09-12 22:04:26,828 (7f4bc6ab4700) :  DEBUG (runtime:88) - Sending packed state data (110 bytes)
> 2019-09-12 22:04:26,829 (7f4bc6ab4700) :  DEBUG (runtime:924) - Response: [200] str, 1308 bytes
The year in the title search looks like it’s a TMDB site issue rather than a Plex API info transfer issue. Go to TMDB and put Inception 2010 in the search and nothing, remove the year and all good.
@BKSteve
May I see some of the file names you are using and can you give an example of the structure?
Also, if these are MP4 files, have you confirmed the embedded metadata has been removed or is correct?
For anyone using /media as their media location, if you’re the Gnome desktop, Nautilus is your nemesis.
Media automatically mounted there exists and is available only to you. Regardless what you put there or what permissions you assign, plex will never see it due default Linux security.
You need to move it (make an /etc/fstab mount) away from there and setup proper permissions.
I have a how-to if needed.
Sorry for slow response.
File name example but many similar, so I’ll stick to the on mentioned.
/Media/Movies/I-L/Inception.2010/Inception.2010.mkv
Owner: admin, Group: users
Metadata not embedded as MKV
What I have noticed if I go to TMDB and put ‘Inception 2010’ it finds nothing.
But if I put ‘Inception’ only
So it looks like TMDB have changed something in their search system so when Plex tries to find a new file from the filename inception.2010.mkv it uses the date as part of the name. Plex Movie DB seems to do the same thing.
Here’s what I’ve tried and which works (TMDB PMDB get metadata):
/Media/Movies/I-L/Inception.2010/Inception.mkv - not work
/Media/Movies/I-L/Inception/Inception.2010.mkv - works
Changing file name and removing year didn’t help but changing the folder name resolved it.
So the search criteria comes from the folder name.
I then tested something else thinking it’s the numbers being assumed as sequence rather than year, and yes this one works.
/Media/Movies/Q-T/Toy.Story.4.2019/Toy.Story.4.2019.mkv - not work
/Media/Movies/Toy.Story.4.2019/Toy.Story.4.2019.mkv - not work
/Media/Movies/Q-T/Toy.Story.4/Toy.Story.4.2019.mkv - works
Hope this helps.
If parentheses are present, the number is interpreted as the year the title was released.
If not present, then interpreted as part of the title itself.
An example for television: Space 1999
The name is “Space 1999”. The name isn’t “Space”, with season 1 starting in 1999.
The naming has always been to put year of release / season 1 within the parenthesis
In your example: “Toy Story 4” is the formal title. It’s not “Toy Story 4 2010”
“Toy Story 4 (2010)” provides supplemental information by adding the year “Toy Story 4” was released “(2010)”.
I understand what you are saying, it just grabs the year after the last ‘.’ in the file name before the file type designation and assumes it’s part of the title. This previously was not the method of operation but as of latter 1.15.x seems to be the way plex grabs from the file structure.
Note that it’s the folder name where plex is grabbing the year and assuming it’s part of the file metadata not the file name.
If that’s the way things are going to be I can work around it but just wanted others to know this is why and that they can find it in the forum and deal with it.
I would however have thought that it would be part of the analysis and anything with 4 digits may be assumed to be a year and if no results with the year, to then search without it automatically rather than get no results at all. I don’t know why parentheses should need to be included to define it’s supplemental information for this search to exclude the year from the search parameters.
To the ‘Space 1999’ example I’d also rather have the one exception for the series rather than every movie I add with its title suffixed with year of release needing special attention, particularly as once the match is correct for ‘Space 1999’ it would add every episode based on the correct source of metadata done under fixmatch.
